can't remove pilot screw tips
  • can't remove pilot screw tips
    ok....Im having a heck of a time removing these tips. I can't get any of them out. i've used acetone/atf mix for a lube and nothing...always been able to get stuff with that mix but these aren't budging. any suggestions? is it worth sending them to someone to do before I mess up something.
    79 SF
    The way I did it was....
    HEAT!
    Use a small propane pencil torch and heat them up...
    Use a "tighten-loosen" approach...back and forth a little at a time.
    But get them pretty hot...
    I hope this helps...
    Tenorman
    Bikes that I have owned and enjoyed...
    1964 Allstate 250
    1970 Yamaha DT1
    1959 Mobylette
    1970 Yamaha JT1
    1995 Suzuki 80
    1978 Yamaha XS650
    1980 Yamaha XS1100LG
    2005 BMW R1150R
      Tips
      are you talking about the idle mixture screws or pilot jets?
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
