Rear Wheel Drive spline
  • mack
    • 2411
    • Ontario, Canada
    Anybody know what the torque spec on reattaching this the the rear wheel hub is? Has to be more than 14.5 ft/lb
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 4015
    From OEM Service Manual:
    Brake disc and hub- 14.5 ft. lbs.
    Final gear case bearing cap- 15.9 ft. lbs.
    Middle gear case drive shaft- 79.6 ft. lbs.
      'Damper clutch and clutch hub', 39.8 ft-lbs.... Look at the exploded view of the wheel on page 5-4.
