I Once Again Screwed The Pooch!
    • 3918
    So, it's confirmed thst the OEM exhaust Gods hate me! I can never get those exhaust studs to show enough thread in the flanges. I can usually get one or two pipes, but the other two give me issues. New gaskets, no residue, all installed by the book, all tricks tried.
    So, the only thing I can do is attempt to remove the exhaust studs. "Ohhhhh noooo" I hear you say? Broken studs? Nope, none broken. In-fact, all seven came out with my vice grips. It's the #2 cylinder, inside stud giving me issues. It's marred-up pretty good from the vice grips. My hands hurt BAD from the pressure of the vice grips. So, I just bought a torch, and will attempt to head the cylinder and and turn the stud with the vice grips. If I cannot get it out, I'll pull the head and see if someone can weld a nut to the stud and hope it does not break.
    Worst-case, I take it to a machine shop and have it removed. It's only April, so I'm not too stressed at this point.
    • 3918
    No-go. head is coming off and cross my fingers it does not break.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      I know you did this, I'm sure but how many gaskets are in the exhaust ports ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
        • 9980
        Once again, I highly recommend this tool.......
        http://www.amazon.com/Irwin-Industri.../dp/B0000CCXVZ
          • 3918
          Hey Done- One
          Greg- Thanks for the recommendation. I have the Harbor Freight version of that. The stud is too small for the smallest extractor to grab it.
            • 9980
            You may have boogered the end too much and ground it down with the vice grips. I've gotten broken studs out with these as long s there's enough of the stud sticking out the get ahold of.
            Great for rounded oil filter can bolts too.
              If you haven't muffed the threads too much, find a couple metric nuts and double nut it. Use the wrench on the closest one to the engine and tighten down against the first one... and just keep turning.
              My local auto parts store carried the right exhaust studs that I needed.
                • 3918
                Tried the double nut first. Was a no-go. Stud is out. Head goes back on in the morning.
                  • 7766
                  I go to the local auto parts store, and look for the spinning rack with the red packs on it. The Chevy small block, late engine, uses the 8mm studs, and comes with really nice shoulder nuts all for about $5. Studs are the correct length for the early standard engine, and will fit the specials as well.
                    • 9980
                    I keep a stick of SS allthread 8mm x 125 and cut them as I need them in any length I want.
                    Works for a lot of other stuff too.
                    • jwhughes3
                      • 2798
                      • Home of the Alamo
                      Didn't they have two lengths of studs as they changed the depth of the exhaust header ring?
                      John
                      '81 XS1100H - "Enterprise"
                        • 3918
                        Yes. Special vs. Standard. I saw what the issue was. Some of the exhaust studs were installed backwards, and some normal. Not sure if the long end or short end goes in the head, but i bought much longer studs (not using stock cylindrical nuts).
                          • 3918
                          Head is back on, no issues. Dots align perfectly. Back to square one with the exhaust install.
