Yamalube carb dip?
    • 3193
    Yamalube carb dip?
    Can anyone tell me for certain if the Yamalube carburetor cleaner dip is safe to dunk the carbs from a MNS. I have only tried it on non painted/coated carbs so far. I sure would hate to take the finish off these Midnight special carb's by doing a prolonged dip.
    • 3193
    Surely someone on this board has tried it on Midnight Special carb's !!!
      I use an ultrasonic cleaner for the carbs. No problems with anything other than the dirt! My MNS carbs will need new paint when I go through them, though. Bike sat for 20 years, and the covers have been painted black like the carbs.
        Are you talking a bout the Yamaha carb cleaner you mix with water? If so that stuff works good for cleaning the dirt and varnish but won't hurt the rubber or paint.
        I've used it.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Have not used it on midnight carbs but I mix it with non E fuel with good results on aluminum carbs. Been thinking of trying other carb cleaners mixed with the good fuel ?
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
          • MPittma100
            • Aug 2011
            • 2359
            Fuel?
            Wow! Mixed with fuel. That's a no-no.
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              Uncle Done hasn't picked up a bottle of Yamalube carb dip in some time. The old formula was supposed to be mixed with gasoline. Today, it's water. He just hasn't caught up yet.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                I have 2 bottles of the old stuff on hand. I remember now that someone told me they changed the formula. The old can be mixed with water for boiling or with fuel for soaking. Never cared for the idea of putting water in my carbs. Don't boil fuel !
                76 XS650 C ROADSTER
                80 XS 1100 SG
                  • 3193
                  I had one black carb that was odd man out. I do not know if it was a midnight special carb or just one that was painted black yet. I will have to see if I can find any numbers on it. I soaked it over a 24 hour period.
                  All of the black that is on the upper bell where the diaphragms go is blistered up in a huge way. The rest which is on the middle part of the body seems ok.
                  This is the three parts water to 1 part Yamaha carb dip stuff. Makes me a bit leary of soaking a full set. The guy I am doing these carb's for is the mechanic that put my 79SF together on pre-delivery, and he is still a mechanic on bikes although they are Hardly's.
                  Is there a different type of coating on the MNS carb's or is it just typical paint? I really do not want to screw this particular re-build up.
                    I have an XS650 Heritage Special that I bought new. The black on those carbs is long gone. My best guess is don't soak them if you don't want to repaint them.
                      Or if you never want them to work right.
                      Fix them so it'll run right and repaint as necessary if you feel the need.
                      • mack
                        • 2411
                        • Ontario, Canada
                        Carb cleaners
                        I was going to do a thread on this, in the summer but I'll just say a bit here. I have an utrasonic cleaner (branson 8510) and have used everything from pinsol, simple green and evenflo carb cleaner straight. The best thing i've found is a product called crystal that hospitals use for autoclave machines. It's aluminum friendly and will remove all the dirt and crap off the carbs and lossen up everything so they can be completely disassembled down to the bare bodies. If yours can be stripped without step one, then just go to the next step.
                        Then I have a big chili pot on a camp stove outside with boiling water. I place the bare bodies in and I boil them for about 10 minutes, then take them out and blow air through the passages. They dry completely almost instantly and I'll repeat as required until all the passages blow clear. Let them cool then you can put them back together.
                        All the small pieces go through the crystal in the u/c and come out looking like new.
                        If your mns carbs haven't been rattle canned black, the boiling won't hurt them at all.
                        mack
                        79 XS 1100 SF Special
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        https://youtu.be/wB5Jfbp6SUc
                        https://youtu.be/RaI3WYHSuWA
                        Frankford, Ont, Canada
                        613-398-6186
                          Yummy. Boiled carburrettors Do you serve that on crackers with an oaked Chardonnay? or between two slabs of white bread with gobs of butter ?
                          Sorry Mack just my warped sense of humour
                            Phil, I thought you would go for a pint with those, being Canadian and all...
                            • mack
                              • 2411
                              • Ontario, Canada
                              It's all good. As for Ray, the first couple passes in boiling water do leave a froth that looks a lot like beer! Change water as required until smell and froth don't look like budweiser and smell like varnish! This method is as good as any and is far cheaper on the pocket book and easier on the nose!
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
