Question Regarding Thread Sizes
    • 4013
    So, again I purchased another pair of air shocks. To my disappointment, the fitting thread size is not the same thread size as the CB1000 air shocks. So, I do some researching and find that the schrader valve size is 1/8" NPT. What??? I measure the thread size of the bolt/plug, and see it's 25/64, closest size down is 3/8". I don't find any 3/8" Schrader valves. So . . . I come to the realization that I have no idea what to think.
    Does NPT threads measure differently than normal standard vs. metric threads?
    • 7830
    YES!!! The NPT stands for National Pipe Thread, IIRC. Pipes measure by inside diameter, NOT outside like EVERYTHING ELSE! You should be able to find a fitting to go from the NPT to schrader, but I'm not sure about it. The other thing is to run nylon tubes between the shocks, and put a schrader valve someplace on the tube. That I KNOW can be done.
