Front Axle Castle Nut Torque
    • 4015
    Just snapped a stud on the axle holders torquing them to 14 ft. lbs. Having followed the spec and she snapped before clicked, I was hesitant to follow the 77 ft. lbs. for the axle castle nut. However, I did so, and found her kinda gorilla tight, and the wheel did not spin as freely.
    Question: HOW LOOSE CAN YOU HAVE THE AXLE CASTLE NUT AND BE SAFE (as long as the cotter pin is there)?
    I tighten my front castle on my bikes down to about 60 ft/lb and a tad more to line up for the cotter pin, haven't come loose yet.
      Not understanding what you say you snapped? You mean you broke one of the shock legs, or you broke the pinch bolt, or you broke the part the pinch bolt squeezes?
      Anyway.. I have never officially torqued an axle nut. German torque.. gootentight.. then advance to next hole for cotter pin. YMMV. My opinion, on cornering, there's a lot of sideways torque going on.. enough to flex the shocks sideways. That axle is the fulcrum point for all this to happen, so it needs to be tight, but not so sure it needs 77 foot pounds. So for the people that actually torque them with tool, do you over torque them to get to the next slot in the castle nut, or undertorque and go back one slot?
        • 4015
        Hey Todd- The axle pinch bolt, which fortunately for me is a stud. I unscrewed the remaining stud with vice grips and I'm headed-off to the hardware store to buy two new ones. 14-ft. lbs. is spec, and she snapped.
          Ahh.. ok. Mine is a bolt/nut combination. Do you think they will have any grade 8 metric?
          And also... what does castle nut torque have to do with the pinch bolt/stud?
            • 4015
            Following torque spec on one nut and seeing it snap, I was hesitant to follow it on another.
              Hey Ian,
              Have to ask, what type of torque wrench were you using on the pinch bolts?
              For such low levels of torque, folks really recommend an INCH/POUND wrench because the accuracy of large torque wrenches rated for 10 to 140 lbs won't be sensitive enough at the low torque values!? JAT!
              I agree with BikerPhil and also Tod...if using wrench select a value a bit lower because of needing to possibly rotate a little more to get the cottor pin slot aligned.
                Ian, that stud had been over-torqued somewhere in it's past, you just finished it off....
                I'll second the inch-pound wrench, accuracy at the extreme ends of the range on most wrenches isn't that good.
                Having the axle nuts torqued to at least the factory minimum is critical, as that is what 'ties' the fork/swingarm ends together.
                  Cheap torque wrenches are only accurate in the center of the scale. Most if them fall off to accuracy within 4% at the ends. After a few years of abusing them, they're even less accurate. Just the same, I concur with Steve. Unlikely the wrench is the culprit.
