Molly or hypoid
  • mack
    • 2411
    • Ontario, Canada
    Molly or hypoid
    When reinstalling the middle drive unit, do you use molly or hypoid to lube the middle driven gear socket (female)and the middle drive unit drive spline (male)connection?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    I'm pretty sure the manual calls for not just a moly lube, but a high concentration moly lube. The stuff almost feels like a warm wax it is so fully of moly. But double check the manual. It will spell it out.
    -- Clint
      • 9980
      The manual is 30 years old. I have the 850FD mod and it's been working flawlessly with the spacer mod with just plain old wheel bearing grease for 50 - 60K miles. That coupling doesn't slide anyway.
      Just sayin'
        • 8797
        That spline shaft should be getting lubed from the gear oil in the unit itself.
        • mack
          • 2411
          • Ontario, Canada
          Lube
          The FSM and the Haynes don't mention anything about lubing this connection but it stands to reason that something should be used. If you look at the lube chamber, I don't think the hypoid would get up that high to hit this joint unless there is a lot of splash going on. I just don't see that happening with two 45 degree pinion gears. They mesh so tight that it would be more like a slow blender in a cake mix. Thats why I asked. Your right though in that the shaft and socket have no movement other than rotation. I'm going to lean toward the molly.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            • 7765
            Either one will work. I used Mobil 1 Wheel bearing grease on mine, and it's still good 60K later. The REAR DRIVE NEEDS MOLLY! It has a LOT of pressure, and rides in and out as the back wheel goes up and down.
            • clcorbin
              • Jan 2010
              • 495
              • Albuquerque, NM
              That's the one I was thinking of! Sorry!
              -- Clint
