XJ carb and caliper parts
  • BillyRok
    • Aug 2011
    • 421
    • Shortsville, NY.
    I'm trying to track down the butterfly shaft seals for my carbs and 2 seal kits for the front calipers...this may be the carb seal number? -- 256-14997-00-00.
    Did some searching but not much luck, thanks for any help you can give me.
    Billy
    • 8962
    As for the front caliper rebuild kit, the 81 XS1100 Midnight Special also uses the same caliper/caliper kit. Beware that some vendors don't know what fits what and you may get the wrong kit. The carb butterfly shaft seals are the same as the 80-81 XS1100 all models. If you are a member of the XJbikes forum, you can contact Chacal (Len), he should have everything correct that you need.
      Billy,
      I believe it's #39 on this fiche. http://www.ronayers.com/oemparts/a/y...8e0/carburetor
      Mike's XS has it, but I'd much rather have OEM, especially when Ron Ayers or Partzilla is going to have them cheaper.
      Throttle Butterfly Shaft Seal Mikuni BS34 and BS38 CV carbs all XS650
