Front foot pegs
  • johanr1
    • Apr 2014
    • 10
    • Pretoria North, South Africa
    Front foot pegs
    I have an "H" model that I am rebuilding
    I am battling to assemble the front footpeg setup.
    Does someone have a diagram or fotos from their bike that they can help me with to get the assembly correct!
    Any help will be greatly appreciated!
    81 H
    XS1100H
      The front footpegs came as an 'assembly', with the footpeg shank (part 3 & 9) attached to the mounting bracket with a special rivet. You have to drill this out to disassemble them. I'd be surprised if you can still get this rivet. To reassemble mine, I drilled the shank and the bracket to a standard bolt size and used a bolt and a nylock nut.
        Hi Johan,
        If the diagram did not solve your problem I can take a picture for you.
        • johanr1
          • Apr 2014
          • 10
          Hi,
          Thanks for the reply, the one I have does not look the same as the diagram.
          It does not have a rivet in.
          If I look at it, the rear enjin bolt goes through the side plate through the footpeg bracket. This footpeg bracket then also have a M10 bolt that fastens it to the side plate. This footpeg bracket does not seem to want to fit here properly although they are marked "L" and "R", that is why I think that I have the assembly incorrect.
          Is the maybe a diagram for the "H" model.
          Thanks for all the help
          81 H
            Originally posted by johanr1
            Hi,
            That pic Jetmechmarty posted IS for ALL stateside 81 models.
              Whups, we weren't paying attention.... He's in South Africa and has a euro-spec version. He needs the pic for the XS11003X0 model.....
                • 2104
                Here Ya Go
                This should be the correct fische:
                In this thread, are some pics that may help: http://www.xs11.com/forum/showthread...uro+conversion
                • johanr1
                  • Apr 2014
                  • 10
                  Thanks guys. This looks like the correct assembly, and for the links with the pictures. Really appreciate the help!!
                  81 H
                    Hi Johan,
                    Forgot you would have the different foot pegs. Also the gear shift lever will be different from ours. Look for posts from James England for the euro different parts.
