XS1100 Sport cafe racer project
  • Mathh
    • Nov 2006
    • 699
    • Beek, Netherlands
    Here are some pics of the building of two Sports (5K7), bought by a friend of mine called Ief Warson from Belgium.
    It all started last year with buying two projects , both Dutch bikes and in a sorry state. Both bikes had been standing for lots of years. Although delivered with a lot of spares we decided we could only build one original bike and one caferacer. And as Ief wanted to drive in summer (read : the summer of 2014 ) we decided to start with the caferacer. Now that would speed up things
    Here some pics directly after the sale... two bikes
    including lots of boxes with parts ...
    MV Agusta Brutale 910R '06.
    Yamaha MT-09 Tracer '15 grey.
  • Mathh
    • Nov 2006
    • 699
    • Beek, Netherlands
    one bike was stripped and the frame went off for blasting and coating, the color is black with a silver metalflake to brighten things up. Engine was tested and it ran, although very rough but on all fours. It was washed with degreaser and painted with VHT black wrinkle.
    All bolts to be replaced by stainless steel ones. Carbs were taken apart and cleaned thoroughly
    Soon frame and engine were married again ...
    frame was altered at the rear to get the caferacer look
    Stock shocks were dismantled and coated and painted:
    And of course the obligatory exhaust stud was broken off .... duhhhhh ..
    • Mathh
      • Nov 2006
      • 699
      • Beek, Netherlands
      Next were the wheels, discs and the front forks ...
      Some nice shiny bolts for the discs with a tiny drop of medium Loctite ..
      then some trial fitting with the newly painted fuel tank in matt silver:
      And time for some new Avon rubber ..
        Good find!......with your involvment, can we expect any MAJOR transformations?.. BTW, any pics of the finished twin-sparred frame mono-shocked XS11 project?(nope..haven't forgotten).
          • 6765
          holy sheetz...that looks bitchin
          2005 Honda SilverWing 600
          2018 Honda PC-Xpress 150
            Is that a 17" rear wheel? I like it!
            • mrhammer2u
              • Aug 2014
              • 472
              • Northern, NJ
              Nice build! Want to see the finished product.
              Rob - 79 SF
              • rambler Shawn
                • May 2012
                • 36
                • Qualicum Beach, B.C., Canada
                Nice work! I nearly went with the wrinkle coat as well. Maybe the next build, looks good
                79F cafe
                • Mathh
                  • Nov 2006
                  • 699
                  • Beek, Netherlands
                  Well, it took a while but as the bike is still not finished due to every session ending in drinking beer …
                  …. I’m gonna post some pics because these stories need a decent end, too many unfinished stories on the internet..
                  Here you can see after we fitted the K&N’s , we made a strut on top of the carbs to hold them, also visible the Fireblade coils with the screw-in red plug wires.
                  Later we rubber mounted the carb struts to stop vibration messing up the floats.. and check out the relocated ignition switch ..
                  We mounted the stock oil cooler and a solid gold oil pan, just to show off ……
                  We fitted a new headlamp with a ring of leds surrounding the H4 lamp….
                  … a T&T electronic Speedometer/Tachometer combination …
                  Turns out that we would move that headlamp several times and to different locations as we were not pleased with the looks.
                  Some nice Brembo brakes on home made adapter plates to get some nice braking up front …
                  Check the adjustable head lamp mount ..
                  Easier to handle oil filler bolt for the middle drive gear ..
                  Then we mounted the stock black downpipes and wrapped them. We bought some empty fat shorties which fitted to the stock downpipes and made some baffles to fit in the mufflers and filled them with ceramic wool.
                  installed a Telefix fork brace ….
                  … and relocated the rear caliper by cutting and welding the stock adapter plate ..
                  ..... will be continued soon ....
                    Hi Mathh,
                    Some nice, meticoulous work goin' on there......as usual, and is normal for you.
                      That is some seriously nice work, and thank you for following up on the unfinished story!
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        1100 seca
                        Can't wait !!!!!
                        WANT TO SEE THE ENDING (finish) !!!!!
                        DID I SAY I CAN"T WAIT ?
                        Being that projects like this are never really done (little things get up-graded) with adding/changing as time goes by.
                        I hope to see more after the final pics as time goes by, PLEASE .
                        76 XS650 C ROADSTER
                        80 XS650 G Special II
                        https://ibb.co/album/icbGgF
                        80 XS 1100 SG
                        81 XS 1100LH/SH DARKHORSE
                        https://tinyurl.com/k6nzvtw
                        AKA; Don'e, UD, Unca Don'e
                          Super work! Hurry up, the suspense is killing me.
                            • 8962
                            Looks great, is that a 17" rear wheel? Nice touch with the caliper at the bottom like a newer machine.
                            • Mathh
                              • Nov 2006
                              • 699
                              • Beek, Netherlands
                              Thank you all for the compliments again. The rear wheel is 2.5x17" ...
                              We still have some sets for sale
