Float Height
  • MPittma100
    • Aug 2011
    • 2359
    Float Height
    The Yamaha service manual specifies a float height of 24.7mm +/- 1mm or 24.7-26.7mm. On the set that I have rebuilt, a height of 24.7 will, ever so slightly, weep fuel on all 4. I am thinking of going to the 25.7 or 26.7 height to stop the leaking. Has anyone set floats at the 26.7mm height?
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    The manuals state 25.7 +/- 1mm. 25.7 seems to be about perfect and if it changes too much it does make it leaner or richer depending on the direction.
      With the fuel we call gas out here, I set floats to 27mm. The ethanol in the fuel makes it lighter, and the floats do not act the same as with 100% petroleum. I made a gauge from an old credit card, and use it on all the floats. With it, I can set all 8 floats exactly the same.
        • 9981
        Drop them .5mm. If that doesn't do it go another .5.
          If you replaced the float needles with other than Mikuni(K&L,etc.), you may find that the internal spring collapes farther than the Mikuni ones causing floats to raise a bit more upon shut-down, causing a slight weep around bowls. Had this happen on the 'evil#3' carb, and found that that particualr K&L float needle compressed farther than the rest, raising float and fuel level upon shut-down.......always figured that was why K&L had five instead of four in a package......better odds of similarilty maybe.
            • 5073
            Ray, did you cut the credit card even to measure from the center rib of the gasket mating surface?
              Yes, it's cut in a big "L" shape so it will fit between carbs/floats. I go from left to right, measuring each float. I just flip the gauge over to measure from the left side, and then the right side of the carb body.
                • 2104
                Another Ex. of a float gauge
                This one I made from an old float bowl gasket, for my '80G carbs:
                  That caliper stood on end and set to .910(23mm) works too.....or.915 above 5,000ft. elevation.
