81 XS1100sh modification question
  • RichV
    • May 2013
    • 374
    • Everywhere
    As most have to, I am using a non-standard set of mufflers on my rebuild with original pipes. They're a set of HD mufflers I have around the shop in great condition and the right size. Unlike the originals these mufflers are the same diameter all the way to the end where they taper a bit. The left side mounted no problem. The right side, however, had a clearance problem
    The bridge of aluminum that extends below the rear brake peddle mount pushed the muffler down way too far. I want them to be lined up with the aluminum bracket but the pipes were pushed down (unlike the left side). I can't stand uneven pipes and this produces a two inch difference.
    So my idea is to cut this bridge off. I don't see how this can cause a problem but with my inexperience on these bikes I might be missing something. So I modified a second bracket I had laying around (unusable due to other mods) to test it out. With that change I was able to mount the muffler even with the left.
    So is this an okay approach? It looks like it will work fine. Here are two photos showing the modified bracket installed and the improved clearance alone with a photo of the bracket I will be modifying.
    The only stress point I can see if from the muffler mount and a passenger's foot on the peg. Unlike the left side, there are two bolts holding the back part of the bracket in place.
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    It's just a bracket for the rear foot pegs. I actually had mine completely removed and then shortened the 1 bolt that goes all the way through. I have a solo seat.
    Rob - 79 SF
      I'm not sure about this, but I think it's going to break opposite to where you cut away. The foot rest mounts on the end, secured by a long engine mount bolt, correct? What keeps the foot rest from pivoting?
      • James England
        • 3039
        • North of England
        What happens when you press your foot on the brake pedal? What's stopping the splined shaft from dropping down when you press through lever?
        • mrhammer2u
          • Aug 2014
          • 472
          • Northern, NJ
          I've seen others that have shaved or removed their's as well. The rear brake is a lever motion so there is no direct down pressure. So far I've not heard of any complaints. Have not yet ridden mine since removing so I cannot personally say.
          Rob - 79 SF
          • MPittma100
            • Aug 2011
            • 2359
            The Worst?
            What's the worst that could happen if the modded bracket cracked/separated above the brake lever?
            http://www.partzilla.com/parts/searc...EST/parts.html
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • RichV
              • May 2013
              • 374
              • Everywhere
              There are two bolts holding the back half of the bracket to the frame. That will prevent the bracket from twisting from pressure on the back foot rest.
              The brake spindle mount is part of the frame. The brake will operate without this bracket being in place. The purpose of the bracket is to provide the passenger footrest and a mounting point for the muffler. That and style.
              Thanks everyone for the input. I'm going to do it but only take out only what I need to give the muffler the proper clearance. I really didn't want to do it at all but I can make it look like it's part of the original design.
              Also have:
                I wasn't concerned with the rear foot rest, but the possible twisting motion applied by the front rest.
                Is there an option to lower the left side to match the right?
                • RichV
                  • May 2013
                  • 374
                  • Everywhere
                  The front foot rest is independent from the bracket with both attached to the rear engine mount. There is a stop on the frame that prevents it from rotating.
                  The pipes would need to be modified to allow the muffler to be lowered to match. I'm not good at bending pipes.
                  Also have:
                    Those brackets on the Specials can break even if they're not modified, so don't be surprised if it does break. Have you thought about carefully 'dimpling' the muffler like Yamaha did? The right-sized socket (with an extension for a handle) and a dead-blow hammer should do the job neatly. Put some masking tape over the area; that will allow you to easily mark it and help protect the chrome.
                    • James England
                      • 3039
                      • North of England
                      ah, different from the European version then, where the alloy hanger is the support for the spindle. That's what had me worried re what would happen when the lever was pressed.
                        James,
                        The EU models have our "standard" type features, and our "special" really is...
                        I know, been working on a '79 standard, and need to get the '80 Midnight Special out of mothballs and ready to ride for the Quail Motorcycle Gathering in May.
                        • RichV
                          • May 2013
                          • 374
                          • Everywhere
                          I didn't think of that. I would probably have to make a larger dimple on these HD mufflers since they aren't tapered like the originals. Maybe a combination of the two.
                          Also have:
                          • RichV
                            • May 2013
                            • 374
                            • Everywhere
                            Follow-up:
                            I modified the bracket and mounted the muffler. Here's some photos showing the results. I think it turned out well.
                            Also have:
