Petcock questions
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    Petcock questions
    re: 79 standard tank
    1. I took apart petcocks to examine. Need to replace the o-ring that goes between petcock and tank. Anyone have a part#? Been searching Google to no avail. Can I go to autoparts store and buy an o-ring(fuel capable)?
    2. The one petcock has a metal o-ring behind the cover plate. Otherside does not. I don't know history of tank/petcocks. Are both sides supposed to have the metal o-ring or no metal o-ring at all? Looks like a spacer..????
    Thanks!
    Rob - 79 SF
    Yes, you can match up the O-ring, make sure to polish the seat so it seals properly. You need that metal wave washer behind the chrome plate, that holds the selector mechanism tight up against the 4 hole rubber gasket. Both sides are supposed to have it. There is a good tutorial on rebuilding these vacuum fuel taps, let's see if I can find it...
    Here, these fuel taps are not identical to our XS11, but the rebuilding principal is the same...
    http://xjbikes.com/forums/index.php?...-w-pics.25058/
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Thanks!
      This may help ?
      https://www.rockymountainatvmc.com/oem-schematic/4
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Rebuild kit
        Rob,
        You may want to consider rebuild kits for your petcocks. Georgefix is an Ebay seller many of us have used.
        2X Yamaha XS1100 Petcock Rebuild Kits
        For that price, you get 2 kits, one for each petcock.
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
        • Prisoner6
          • Aug 2013
          • 1184
          • Phoenix, AZ
          Wave washer
          P.S. As for the "wave washer" that fits behind the chrome cover plate ...
          I don't know of another source for it, but you could try Andreas here on the site. You can PM him here:
          andreashweiss
          Marco
          1979 Honda CBX
          WE MISS YOU, DON
            • 4015
            Hammer- using Phil's link, the Yammy number for the "gasket" in-between petcock tower and tank is: 1J7-24512-00-00
            The "wave washer" is: 1J7-24518-00-00
              http://www.carolinacycle.com/OEMpart...XS1100F_-_1979)
              • mrhammer2u
                • Aug 2014
                • 472
                • Northern, NJ
                Ian,
                That gasket has the bars. Mine is just the oval. Trying to find the oval and the wave washer. Will try Andreas....but I think he's on a fishing trip til 2/15.
                Rob - 79 SF
                  If yours doesn't have the bars, it's likely going to be round. Get one locally.
                    • 4015
                    Hmm. I was not aware of any other variety of gasket besides the one with bars, and I have A LOT of XS bikes. Maybe your's is not stock. If it's the gasket that goes between the petcock and tank, the part number I supplied is the proper gasket. More than likely a stretched-out round gasket.
                    • Prisoner6
                      • Aug 2013
                      • 1184
                      • Phoenix, AZ
                      ... Maybe your's is not stock. If it's the gasket that goes between the petcock and tank, the part number I supplied is the proper gasket ...
                      Yes ...
                      Rob, if you have the stock XS11 Standard petcocks, then that petcock-to-tank gasket should have those crossbars (just like the one in the Rebuild Kit link above).
                      Re the "wave washer" ... every parts house/supplier I looked at showed it as obsolete/not available.
                      So, again, check with Andreas ...
                      Marco
                      1979 Honda CBX
                      WE MISS YOU, DON
                      • mrhammer2u
                        • Aug 2014
                        • 472
                        • Northern, NJ
                        Here's a pic of the petcock....I'm assuming it's stock?
                        Rob - 79 SF
                          It uses a round packing (o'ring).
                          • Prisoner6
                            • Aug 2013
                            • 1184
                            • Phoenix, AZ
                            Definitely not stock ...
                            Here is a pic of what the petcock/tank area looks like with a stock petcock setup:
                            Marco
                            1979 Honda CBX
                            WE MISS YOU, DON
                              • 4015
                              Everybody STOP for a second and listen to Marty. He obviously picked up on the fact that Hammer has Special petcocks on his Standard.
                              Taken from the following thread:http://www.xs11.com/forum/showthread...hlight=petcock
                              Marty posts:
                              Those seals come in petcock rebuild kits. If you have a good hardware or auto parts store, they can match it up for you.
                              Part number 2W6-24512-00-00 is available. Yamaha Parts House has them for $2.95 each.
                              Items 15-28
