Last night I reviewed the following in the repair section under Electrical, charging / tach problems...
The resistance between the brown and green wires should be 3.5 ohms +/- 10%. These are the wires that go to the field coil of the alternator. The brown wire carries current from the battery and the green wire goes to the voltage regulator.
With the connectors back together turn the ignition on and you should measure about 12 volts between the brown wire and the bike frame and it should be less than 1.8 volts on the green wire.
Then start the bike and as you rev the engine the green voltage should go up to 9~11 volts if the regulator is working properly. If you measure battery volts on the green wire with the ignition on and engine not running then the regulator is not working and the alternator will not put out any current.
I tried this test and got less than 1.8 volts with bike not running. Actually I got about 0.5 volts. Then when I started bike I got about 5.5 volts. As I revved the motor, I got less and less voltage. Is this indicating a bad field coil or a bad regulator / both or neither???? I'm totally confused.
Thanks,
Tom B.
Thanks,
Tom B.
