Reading 650Mark's post regarding his passenger backrest for sale (also can be used for driver), I've been looking for a small backrest that I could use with stock seat that does not look crazy. Just a small pad that sticks up to rest the smole of your back on during long rides. I know they make 'em for HD's, anybody seen them for our bike's? Not really sure where it would mount though. Not much room.
Driver Backrest
Driver Backrest
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Tags: None -
In the day, the backrest that will work for the driver and passenger mounted in a tube on the rack. two bolts or pull pins and you slide the rest in or out. Not sure what is available, but you could probably build something.....
Heck, once I get over this creeping crud, I could probably put something together. I would use stainless so it looks good, and will not rust. Problem is, it would probably be about $200 for me to build and ship it!
check with andreas, and see if he has that type of rack. That would be a starting point, and then it's just the backrest.
My $0.02..Ray Matteis
XS1100 SF Bob Jones worked on it! -
Unfortunately, the slide-in backrest like used on the Venturer's style carrier rack won't slide out far enough for riderIn the day, the backrest that will work for the driver and passenger mounted in a tube on the rack. two bolts or pull pins and you slide the rest in or out. Not sure what is available, but you could probably build something.....
My $0.02..
. It has to slide in carrier rack tubes far enough(approx. 3") in order for the thumb wheels to hold rack in place.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Ian:
You might be discouraged by the reports of the other members, but if you still want to see the rack/backrest, I have an extra one, although it needs some loving to make it really nice.
I am probably only 45 minutes away if you wanted to come and see one on a SF.
I haven't mounted it yet to see how close it comes to the driver... but it's no problem to throw it on now that I'm finished with the transmission fix.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
Hey Mike- Thanks for the offer. In the Summer, I ride the bike naked with no screen, trunk, rack, etc. So, the "pillion" pad would have to be something mounted to the frame. I saw a guy on eBay make one out of a headrest. I don't want to take away the look of the bike, so it may not work.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
-H. FordComment
a picture worth a thousand words... but very few for it..
i found the info about this nifty little rig a few years ago...
now i can't remember any of the info....
seems like it was somewhere between $100-$150.
which is why (Mr. cheapskate) i never got one.1979 XS1100SF Special.78 E motor/carbs, Jardine 4-2 exhaust, XS Green coils, Corbin seat, S.S. Brake lines, Hard cases, Heated grips.
Most bike problems are caused by a loose nut connecting the handlebars and the seat!!Comment
I bought one several years ago from these guys to put on my Honda Magna after I had back surgery and needed the support for a bit. A bracket bolts onto the seat pan and comes through the foam seat. The backrest bolts onto the bracket so it's also removeable and would fold forward for passengers. Not sure if they have one for an XS1100, but should be able to get one. I had them make one special for my Magna.
Transform long rides into pure comfort with custom-fit, adjustable driver backrests and premium touring accessories engineered for Honda Goldwing, BMW, Harley, and 200+ bike models. Upgrade your seat, eliminate back strain, and ride further without fatigue. Claim your custom backrest and upgrade your ride today!Jason
Montgomery, AL
80 XS1100SG Daily Driver
81 XS1100SH (Getting ready for an engine rebuild)
86 Honda Magna V45 (sold)Comment
.....that is so wrong
, as I'd buy that exact one pictured if you or someone here could locate the source.
With the brain trust we have in our members, this should be an easy challenge.
Could start with an office chair backrest....-Mike
I found the source: revrider.com. They were sold on ebay. Emailed the guy to see if he has any more, as the listing is no-longer active.1979 XS1100F
Also sent an e-mail.....to purchase directly. See what happens
Yup, that's the one!!
Good thing we have a great group of researchers!!
and only a few forgetfull ones as myself...
I've forgotten more then many will ever learn...
i just rebuilt that!!!
hmmm, maybe that was 40K ago.... oops....
On a serious note, it does look like a really nice backrest option.1979 XS1100SF Special.78 E motor/carbs, Jardine 4-2 exhaust, XS Green coils, Corbin seat, S.S. Brake lines, Hard cases, Heated grips.
......cept for the hole thru seat retainerYup, that's the one!!
........I'd just opt for the straps that go around and under seat like the ATV seat covers alot of us use here
Recieved a return e-mail today. Still makes them, but only has pieces to complete one at this time due to cold, which has limited painting pieces for assembly
.........what, no heated indoor man-cave?
Anyways, apparently still makes them, and are $149 and some change+shipping.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
