Strange electric thing poped up
No problems so far
Well borrowed a battery from a friend not the exact size but fit and has been working a few weeks now. Hmm just had to believe a year and a half would kill a battery.
Bike does set outside all day in the Florida weather. Comes home and spends the night in the garage.
JeffLeave a comment:
Amps
A Marine supply store should have a decent Blue Sea amp meter. I have one on my boat. Most things are run through it.
Also have a matching volt meter. Volts at a glance, turn something on, like a light, and the amp meter will show it.
In the book " Living on 12 Volts" the author says a fully charged battery after sitting for a while is 12.75 volts, and a 50% charged battery is 12.25 volts.
My larer batteries have no problem showing these numbers.
My new battery for Yami took a while to come up to charge. Also a regular car load tester, does no favours to a bike battery. There is just not a lot of cranking amps in these things. So the battery might be showing 12.6 volts after sitting for an hour. I would check it again after 24 hours. If it is dropping down towards half charged, and also has trouble cranking, and is a few years old, I would go straight to the battery shop.
If a new battery does not fix the problem I would be checking for drain as others have described.
My solenoid / rectifier thing shorted when I connected the new battery.
Unkle CrustyLeave a comment:
Jeff,
If you don't want to wait and watch the battery for hours, see if you can dig up an inexpensive ammeter. Put it in series with the battery positive terminal and the positive battery cable when the engine's not running and that'll let you know if there's a drain on the battery or if the battery is toast.
If there's a drain, pull the Main fuse and check again. If there's still a drain the only thing between the Main fuse and the battery is the Regulator/Rectifier output wire -- it is not fused.
There's an Isolation Diode in the Rectifier that might have shorted and turned into a fancy wire instead of a diode. Everything will work fine while the bike's running but it'll drain the battery though the Rectifier bridge when the engine is not running.
.Leave a comment:
If you think the battery is bad, why not be sure and try what CZ suggested to make sure there's no leak
Get an amp meter or a test light, and hook the ground cable up to the battery. Put the amp meter or light between the red battery lead and the positive battery terminal. Does the meter read any milliamps, or the light glow, even faintly?
If not, check the brushes in the starter motor.
If so, start down the wiring line and unplug the next plug. As soon as the current stops when you unplug a connector, you have your problem spot. I don't have a wiring diagram for your bike, so I can't be more specific, but you get the idea. I think the regulator is next in line, or the auxilary power terminals?
CZLeave a comment:
Hi Jeff,
Either Bad battery OR the bike has an electrical drain. Wire shorting somewhere.?
PhilLeave a comment:
augh
Crap ole crap. Had it on the tickle all night, took it off this am, fired up drove to work (little high on the rpms) It sat all day, and went to go home click click .... I think the battery has to be bad, kind of like it leaked out all day.
grrrrrLeave a comment:
The fact that the alternator puts out 14+/- should keep the battery well. If not riding as in winter storage a tender should do the same job. Yes/no ?Leave a comment:
Thanks Orange
Good little project for me today thanks will go out and see whats up beautiful day for something like that.Leave a comment:
Just want to clear up that 12.4 volts is only half charged. If a battery sits like this it will sulfate and die a premature death. 12.6+ is fully charged, resting voltage. Bikes tend to undercharge a bit on idle so every ride can leave you with a charge deficit which can add up.
Keep it on a tender or check the voltage regularly before you ride. If you check just after your ride you will be reading a surface charge. Let the battery rest for a while at least before you check the voltage. If it's below 12.6 trickle charge it for 14-16 hours.Leave a comment:
The Geezer rectifier/regulator gives full charging at much lower revs than OEM and this enables the battery to still charge in heavy traffic situations. I fitted one to my last project. Well worth using one if in traffic a lot...Leave a comment:
Fuse block
I want a fuse block. Previous twits removed it and put in inline fuses. I have a fuse block from my spare bike, but I like the TC one better.
Some days we learn stuff when we least expect it.
Unkle Crusty*Leave a comment:
Hey Jeff,
Yep, I still provide/resell these fuse blocks..mine is a 6 slot.
What you can do as a temporary(SAFER) fix is to pull the wires from that fuse circuit with the broken blades/clips....put 1/4" crimp on wire connetors onto the wires....then get a spade fuse and connect it to the wires bypassing the OEM broken brass clips. Then when you get the replacement fuseblock, you can just plug in the wires onto the blocks pins.
However, you may want to replace the crimp on connectors with the ones that I also provide /sell with the block....see the advert that BikerPhil linked to....scroll down to post #10. The link/tech tip that Schming provided is good info on installation.
As you saw from your charging tests....the bike/engine doesn't reach maximum charging current until ~3 grand or above....so when you're riding to work, you want to be sure you're running it in a gear that keeps your rpms at or above the 3k range, and realize that it also has to power the headlight, ignition, driving/brake/turn signals, ignition, AND also charge the battery!!! So...lugging along at 2k rpm and you're probably not generating enough juice to properly charge the system.
Aside from the battery to frame ground cable, don't forget the ENGINE to frame ground strap down low on the engine/middle drive case to frame connection. Also, I think you have found the 3 large white harness connections behind the fuseblock mounting plate...the connectors for the ALT to the harness and ensured they are clean/corrosion free, and not partially melted!!
T.C.Leave a comment:
Check out post #10 in the link below, Topcat sells members the replacement fuse block that uses the blade fuses. Problem with replacing the OEM clips in the old style box is the glass fuses aren't as readily available, hard to find if you're in a jam.
Leave a comment:
Leave a comment:
