cylinder head
  • Filter
  • cylinder head
    Anyone know if a 1980 xs11 special cylinder head will fit a 79xs11F?
    79 XS1100 f (BIGDOG)
    80 XS650 Special
    85 KAW 454 LTD
    Dirty Dan
  • #2
    Yes.
    Randy
    • #3
      Looking at the list of differences in models it looks like the exhaust valves were enlarged and increased duration. The piston crowns were changed as well. I thought the piston crown change may have been to compensate for the larger exhaust valves. So I guess that is not the case?
      I have been having problems getting a cam cap stud to stay in the head I have. I installed a hekicoil and installed an automotive hardened stud, well, at least the parts store called it that. Everything went fine until I started torqueing down the nuts. The stud snapped just before it reached 7 lbs of torque. Had to re move this one and in doing so, I messed up the treads the hekicoil was using. Now the hole is too large to hole the helicoil. I thought about trying JB weld or something like that, but worst case, a different head.
      80 XS650 Special
      85 KAW 454 LTD
      Dirty Dan
      • #4
        Broken Stud
        If you snapped a stud at 7 lbs of torque you had better check your torque wrench!
        Ken/Sooke
        • #5
          That was the first thing I though of too. The torque wrench is fine. Had it checked and it was 1/2 lb off at 20lbs. I believe it was a bad stud.
          80 XS650 Special
          85 KAW 454 LTD
          Dirty Dan
          • #6
            The problem you are having is because you need deeper threads to hold the hardened bolt to full torque. The fix is to stack 2 or 3 helicoil insers in the same hole. It's a little more work but not all that tricky. If the hole is competely hosed, look for something called a "keensert." I'm not to sure of the spelling on that but they hold like hell.
            Geezer
            • #7
              Hey Greezer,
              Thanks for the info. When using the Kkeensert, is it neccessary to purchase the insert tool? They are quite expensive from what I found on the web.
              80 XS650 Special
              85 KAW 454 LTD
              Dirty Dan
              • #8
                Hey Greezer,
                As I recall the insert tool was an 3/8" American tap but I haven't installed one in 20+ years. Any way you drill and tap the hole, screw in the insert with your fingers then tap down the locking pins with a hammer. You won't find a stronger fix.
                Geezer
                • #9
                  I think thats just what I'm looking for. Thanks GReezer. Now I just gotta find out where they sell them at.
                  80 XS650 Special
                  85 KAW 454 LTD
                  Dirty Dan
                  • #10
                    Hey there Dan and Geezer,
                    I just looked in my copy of MSC Industrial Supply Catalog, and they have a product called a Keylock insert, along with HELICOILS, but nothing called a Keensert/kleensert!?
                    Their web site is msc web site
                    Found under Taps/dies/thread repair section. They show stainless steel metric ones(Keylocks) that don't require a special tool for insertion. Inner threads as low as M5x0.8 @8mm deep, M8x1.0 @12mm deep, and other sizes, low as $12.25ea.! HTH?
                    • #11
                      Hey TC,
                      Thanks for researching that! I appreciate the info. I will check it out. I did just finish torqueing down the cap and it held. I filled the hole with JB weld Then Threaded in the heli-coils I had left. I then threaded in the new stud into the heli-coils. So the jb weld is on all contact surfaces of everything. It is suppose to hold at up to 600 degrees so hopefully it will stay put. I have used it in many applications but never a stud in an aluminum head. I plan to run it a very short time and pulling the cover again to check the stud. I will be watching it close for a while. If it looks like it is not keeping the torque I will go with one of the inserts you and Greezer have spoke of.
                      80 XS650 Special
                      85 KAW 454 LTD
                      Dirty Dan
