Hard to push backwards
  • Coopz
    • Feb 2010
    • 40
    • Adelaide, South Australia
    My awesome dad has given me one of his restored XS's ('81 RH Sport) to ride. She looks and rides like a new bike. The strange issue (that I suspect is shaft related) is pushing it backwards when I'm trying to manoeuvre her in the garage. The bike rolls forward very easily but reverse is a real heave. I'm pretty big and its a full blown push to get her backwards. Is this a issue with the shaft or some weird bearing issue? I cannot pinpoint the exact part that's making it so hard. No centre stand either to diagnose the cause.
    First suspect would be rear brake caliper piston is not retracting properly causing brake pad drag on rotor.
    Since you state your decent size, a quick check could be acomplished by rocking bike towards you while on side-stand, lifting rear wheel of ground. Reach down and rotate wheel forward and backward for any noticable resistance difference between the two directions while listening for excessive brake pad drag.
    • Coopz
      • Feb 2010
      • 40
      Ah cheers, as soon as the rain stops I'll have a look, didn't dawn on my to look at the brakes.
      • TomB
        • Aug 2006
        • 967
        • Cumbria, UK
        My daughter has a little Chinese 125 that has the same issue, that's the front brake caliper. (drum on the back) I've stripped it and can't find anything wrong so assume its just badly made, and the silver lining is it makes hill starts for my newbie daughter a lot easier.
        Tom
        • vedgar
          • 311
          • Clarkston, Michigan
          Tap with bubber mallet
          Tap the calipers lightly with a rubber mallet before you move the bike around. If it moves easier then the calipers are sticking.
          79 1100 SF Carmine Red stock
          85 Honda v65 Magna
          • Coopz
            • Feb 2010
            • 40
            Its got new pads so I suspect they are the cause.
              • 2139
              The rear brake on all 3 of my XS's make a squonking noise when I push them backwards, although the brakes are not dragging enough to make it hard to push.
              • Pat Kelly
                • 3046
                • Golden Valley, AZ
                Why not use the centerstand?
                Pat Kelly
                <p-lkelly@sbcglobal.net>
                1978 XS1100E (The Force)
                1980 XS1100LG (The Dark Side)
                1999 Suburban (The Ship)
                1994 Dodge Spirit (Son #1)
                1968 F100 (Valentine)
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Because of the last sentence in post # 1
                  CZ
                  • Jeffintampa
                    • Apr 2011
                    • 344
                    • Zephyrhills, Florida
                    Hard push back
                    Mine does that from time to time, I spray the rear axel on the chrimp side down around were the brake rides, and the front axles with WD40 and that helps tons.
                    Bike History:1980 XS 1100 special current bike
                    1980 XS 850 special wife sold
                      • 2074
                      Make sure the pads are not sticking-I just went through that as the bike had to sit.
