Gasket Set - Why eight small 0-ring seals?
  • RichV
    • May 2013
    • 374
    • Everywhere
    Here's another opportunity to prove how inexperienced I am with this bike.
    I purchased a gasket kit and it has all of them (except the breather cover gasket which I got from another source). I know all of them provided except for the eight small 0-rings (I know what the four large ones are for).
    My problem is I don't know exactly what they are for. I can see a couple being used in spots but not eight. Also why are there eight? That's a particularly round number which has meaning to a four cylinder engine.
    I've been in the manuals and searched the site with no joy.
    They are about the same size as the one between the case halves for the oil feed tube.
    Thanks again for all the help.
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
    If I remember correct they are for the valve guides. So unless you were to remove the valve guides you would not need them.
    Someone correct me if I am wrong.
    • RichV
      • May 2013
      • 374
      • Everywhere
      That makes sense. On the parts breakdown they show o-rings with the valve guides. They were a good so I didn't replace them.
      Also have:
        You took the valve guides out? or did you just have the oil seals off the valves?
        The valve guides need to be pressed out.
