? about triple tree top piece
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    I need a new top piece of the triple tree. Are the 78, 79 and 80 all the same? I have an xs1100 special. I see them on ebay from $20-$50. Condition is not important since I plan to paint it anyway,....just want to make sure I get the right one.
    Thanks!!
    Rob - 79 SF
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    I'm talking about the clamp such as here....
    Rob - 79 SF
      • 7738
      It MUST be from a '79-'81 SPECIAL ! The upper and lower need to line up, and the fork tubes are a different OD between the Standard and the Special. I think the one you showed on ebay is a standard. The frame number will tell, and I'm 99.9% sure 2H7 is Standard only. Check this site for the proper numbers first.
        • 9980
        2H7 IS a Standard and that upper clamp won't work on your Special.
        3H3 is a 79 Special, 3J6 is an 80 Special, 4H3 is a 80 MNS, 4R0 is a 81 Special, and 4W1 is a 81 MNS. Any of those should work
        • PMKXS11
          • Mar 2013
          • 100
          • Rockford, Il.
          I have a really nice powdercoated one for a 79 special that I wouldn't mind parting with.
          '79 Yamaha XS11 SF (project)
          '11 Harley Nightster (street)
          '03 KTM 125sx (dirt)
          '03 Suzuki GSXR-600 (track)
          '73 Jawa Californian (collecting dust)
          • Eveready1100
            • 539
            • Childers, Queensland,Australia
            Where'd that come from??
            The tubes are the same O.D. for all of them.
            • mrhammer2u
              • Aug 2014
              • 472
              • Northern, NJ
              Thanks everyone, especially BA for being so specific
              Rob - 79 SF
              • mrhammer2u
                • Aug 2014
                • 472
                • Northern, NJ
                [QUOTE=PMKXS11;454816]I have a really nice powdercoated one for a 79 special that I wouldn't mind parting with.
                How much? I PM'd you.
                Rob - 79 SF
