Iota progress
  • mack
    • 2411
    • Ontario, Canada
    Iota progress
    I know my signature says I'm in the process of restoring an E but haven't posted any progree reports, so here what I've done so far.
    Chrome has been completed.
    Powder coating is almost done. Still have the wheels, rear caliper and thrust plate to do.
    The motor has been stripped and all the internals have be cleaned. I've cleaned and polished the covers and dry fiited everything today.
    As you can see, one of the locating dowels is preventing the Jugs from dropping in. If I remember correctly it was tough getting one side up during removal. I can't get it out so I have to figure out something on that.
    The fairing, hard bags, sides and tank have been painted but I haven't taken pictures. So it's coming. I hope to have it ready to ride for the spring. Next thing will be to plasti guage the big end, crank mains and cams. Then I can start putting the motor back together. If the big end bearings don't pass, I'm screwed. I've looked but can't find any new brown shells. Without them, what I have here is several big piles of very good parts.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Purty.........
    • Gmac
      • Aug 2014
      • 256
      • Huntsville, AL.
      Have you checked any manufacturers to see if there are cross matched bearings that you can use?
      I can't believe something like a bearing shell could not be rebuilt or built outright by one of them if they had the originals to work with.
      It might not be cost effective but it sure beats a pile of expensive parts.
      That chrome is outstanding btw.
      79 SF & 80 LG MNS
      73 & 74 RD 350's
      73 Honda CL 450
      Graveyard - '81 XS850 Special
      • mack
        • 2411
        • Ontario, Canada
        Steve I haven't forgotten our discussion. I'm keeping track and will give it all to you in one big shot, photo's, video's etc.
        Gmac- I'm not going to get too worried until after the guage testing.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
          I have a few mains, but I'm not sure what colors I have left. I WILL need some for my '78 project, so once I gauge mine, I'll know what I can part with. Let me know when it gets close, as I'd like to try and keep one more on the road....
            Mack:
            That's an incredible job. Museum quality.
            Nice work area too!
            How did you pick the chrome plating place? Most refuse exhausts because it dirties the acid tank.
            • timoteo539
              • Oct 2014
              • 27
              • Minersville, Penn.
              How much did the chrome plating cost?
              Tim McNally
              79 XS Special- Needs transmission
              80 XS Special - Frozen motor
              80 XS Special - Lookin' Good
              76 CB750 Four
              2000 Nomad
              • mack
                • 2411
                • Ontario, Canada
                Diver Ray- The mains aren't the problem it's the connecting rod halves I may need. I bought a complete kit of main shells earlier this year and only need one colour, so if you need some colours later just PM me.
                Radio - I took the chrome to a guy in Ottawa who does all the copper roofs and stuff there. He cut the exhausts in half and rebuilt them from the inside out using copper, then he nickled, then chromed them. They will never rust out again! He was the same guy who did the gold plating on my LH.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • mack
                  • 2411
                  • Ontario, Canada
                  plating
                  Tim- I think it was 2K for everything you see on the table and a couple things under it that wouldn't fit on the table while I took the picture. That also included the exhaust restoration.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    • 2104
                    Prettiest Pile O' Parts I've ever seen
                    Is it possible to clearance the jugs, where the locating dowel resides, so it will drop down where it belongs ?
                    Do you have any pics of the exhaust internals, stock and the reconstruction ?
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Plating
                      Hi Mack,
                      Looks very nice. You mentioned that your guy did some Midnight Special gold plating. Does he also do black chrome for the exhaust? Could you post his contact information?
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                        Miike,
                        The border between us and Mack could make using his vendors a challenge. Put "Spica restore" in the search block. He documented everything very well.
                        Cermaic exhaust coating
                        The product for the exhausts was from Techline Coating and is called Thermo Chrome. The colour was 2000 degree Black. On top of that to give it a shine was a product called Therma seal. Both applications are applied by spray then baked on at 600 degree.
                        __________________
                        mack
                        • Eveready1100
                          • 539
                          Mack, to remove a stuck dowel, get a 10 mm dyna bolt
                          get a smallish ring spanner, or a piece of flat steel with a suitable hole in it and slip it over the shaft of the bolt sleeve, then stick the bolt down into the dowel and tighten the nut till it binds with it. Slide the spanner (or piece of steel) back up under the nut and tap it upwards to pull the dowel out of the hole.
                          Once out, undo the nut and you should be able to pull the dowel off the dynabolt, give it a clean up with.a file to restore a looser fit in the recess, and refit it.
                          I've done this a number of times in the past, and it worked great every time.
                          • James England
                            • 3039
                            • North of England
                            Very nice indeed! It's looking like a first class, lovely job.
                            • mack
                              • 2411
                              • Ontario, Canada
                              Thanx
                              Thanx everready, great tip, this is why I love this site so much. Not just because I love these bikes, but also because the knowledge their riders have is profound.
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
