Bought a spare
Lube it.
Thank you for the info men.
I do use the 15 / 40 HD diesel oil in the bikes. Have not changed the oil and filter in Laramie so far.
Unkle Crusty*Comment
Need parts.
I need: Brake cylinder kits, brake pads, brake pistons, fuel taps that have the on / off / prime positions, tyres. Any suggestions who has these bits that are not made in China. I could use taps with just an on / off and block the suction hole, but that would eliminate reserve.
I will check locally if they can make brakes hoses, but if they are available online?
Meanwhile Yami the 79 XS11 Special broke a header pipe. Mac 4 into 1 about four years old. Bought chrome that promptly rusted. Yami ran good on these pipes. Headers are thin wall.
Spare MNS came with 4 into 1 Kerker. They are now on Yami. They look like a better build. I still need to pull the baffle out to remove rust that is floating around. Yami runs okay on these, but still need to do a freeway run.
Unkle CrustyComment
