How do I remove the Reserve Lighting Unit?
  • sthomag
    • May 2009
    • 60
    I've installed a new Truck-Lite LED headlight, and it's great, except that when I switch from high beam to low beam, the high beam stays on and flickers.
    I think what is happening is the RLU is getting confused because of the low current draw from the LEDs, causing some kind of feedback loop. I want to remove the RLU, but the wiring diagram's a little confusing.
    Has anyone done this? I guess I can figure it out if I take the time, but any help would be greatly appreciated.
    To bypass the Reserve Lighting Unit: Unplug unit and connect blu/blk and blu/yel together at the harness plug. That should do it.
      The flicker has nothing to do with the RLU. I removed mine when I installed HID bulbs and didn't put it back when I installed the Truck-Lite bulb. The Truck-Lite bulb does flicker on high-beam at idle. If you raise the RPM, it should shine solid without issue.
      • sthomag
        • May 2009
        • 60
        I'm talking about a different thing. The slight flicker at idle is obviously due to lower voltage. I'm sure that can be fixed with a couple of relays, now that the RLU is gone.
        What I'm talking about is that when the high beam is on, and the light is drawing 40 watts (both LEDS on), and then I switch to low beam, the high beam doesn't go off. It strobes. At the same time, the RLU indicator light flashes, too. The only way to stop the strobing is to turn off the ignition.
        I think it's because the RLU is reacting to the sudden drop from 40 to 20 watts.
        I've removed the RLU using BikerPhil's kind instructions, but haven't ridden the bike yet because it's raining cats and dogs. And I just shined up the bike. Vanity, thy name is bikers. Anyway, I'll let you know how it works out.
          Ahh! Gotcha. Yeah, that makes perfect sense.
          • sthomag
            • May 2009
            • 60
            Removing the Reserve Lighting Unit did the trick. The Truck Lite LED headlight now switches between High and Low with no problem.
            I can recommend this light. It's very bright; the beam is a little uneven, due to the faceted reflector I guess, but it's very effective. I saw complaints on the Amazon site that it has an "X"-shaped pattern, but they must have changed the reflector, because I don't see any such thing. It has a very sharp cutoff on low beam, but still throws enough light above to light up signs, etc. On high beam it's just terrific.
            Just make sure to disconnect the RLU before you install it.
