Carb Rebuild
  • Aches n Pains
    • 349
    • Reston, Va.
    Carb Rebuild
    Getting ready to re-build a friends carb set. I know one idle adjusting screw port needs to be tapped and there may be more. Does anyone know the tap sizes for:
    Idle adjusting screw
    Main jet
    Pilot jet
    Pilot air jet
    Any other carb threads I'm not thinking of
    I'd just like to have the right taps on hand before I start.
    Thanks for your help,
    Doug (Aches n Pains)
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    no idea. I have a few carb bodies laying around though. if you get jammed up let me know and I'll see what I have.
    1980 LG
    1981 LH
      I ordered a tap for the idle speed screw when I turned a #1 carb into a #3 carb. I 'll have to look at it when I get home but it's the same thread as the mixture screws on a 78 - 79 carb.
      I had to order it from China.
