helpppppp from the boys needed
  • James England
    • 3039
    • North of England
    Looks like a nice bike. Well worth getting that stud problem sorted out!
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Very nice
      bike !
      Was following thread and I have one exhaust nut that the allen is now stripped. I'm going to cut a slot in it with the dremel cut off wheel, see if I can get one of my impact driver bits in there held by vise grip.
      Was wondering does anti seize help keep the exhaust nut re-movable, I'd think it would just burn off.
      Anything that would work ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
        • 8077
        Anti-seize compound is supposed to work in high heat applications. It even comes in heat ranges.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Thanks Marty !
          I've been using it on the studs but had no idea if it was doing any good. Never saw heat ranges on it ?
          76 XS650 C ROADSTER
          80 XS 1100 SG
            In a pinch, you can use Pepto Bismol as anti-seize on exhaust bolts....
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Pepto, really, never would have thought
              Now Ex-lax I could believe
              76 XS650 C ROADSTER
              80 XS 1100 SG
              • wjw11teen
                • Mar 2014
                • 93
                • Valleysprings.S.DAK
                gold never seize is good for some pretty high heat... its used regularly in high pressure/high heat steam systems
                81 SH gifted to SON
                • James England
                  • 3039
                  • North of England
                  bike !
                  Do you mean the stud has sheared off? Cutting a slot in the stud (is that what you meant?) will weaken it, IMO. It will most surely snap the edges off at the slot when you exert any force on it. They're weak enough even in one piece...
                    Hey James,
                    I think he means the recessed Allen Keyed OEM style exhaust NUT has stripped out inside. Around the exhaust there's not a lot of room to try to put a pipe wrench around the round nut. It usually does have some knurling around it, but also not sure if he would have enough room for even a pair of vicegrips.
                    Done, was wondering if you would be able to dremel/grind some flat edges around the nut to where you could put a socket on it....but your single large slot and large/wide impact driver sounds about right. Might try also spritzing it with some PB Blaster as well before attempting to loosen. Good luck!
                    • James England
                      • 3039
                      • North of England
                      Hey James,
                      I see what you mean now. The Allen socket in the OEM nut has rounded off inside. Cutting a slot or making faces for a socket or ring spanner would probably work...
