Mr Dragonrider?????
  • CMA1
    • Jul 2003
    • 114
    • Ontario, Canada
    Mr Dragonrider?????
    Hi Dragonrider,
    I read your post re: by-passing the headlight relay.
    I just want to get it straight... My brain goes into spasm when I encounter things like relays and sealed boxes.....
    You wrote:
    "Bypass the relay, connect the power wire to the load wire." at the end of the post.
    Does this mean "ONLY jumper these two and then I throw away the relay? I already got rid of the RLU and a couple other "thingies' LOL (yes I identified them before pulling them) LOL
    I also would like info ... to acquire your books!
    Thanks much
    - Larry
    '79 Special
  • CMA1
    • Jul 2003
    • 114
    • Ontario, Canada
    Well it is okay... I figured it out. !!
    I took the headlight relay apart and found corroded contact points (lots of scale on the points) and an airgap that looked TOO large to me.
    I cleaned the points , re-gapped the points to .030"
    The relay works again....
    But I think I will install a switch... hahahahaha
    Ride safe, Larry
    '79 Special
    • Dragonrider
      • 1219
      • Garland, Texas
      Hey Larry!
      Glad you figured it out.
      Info on the books is here:
      CUAgain,
      Daniel Meyer
      Author. Adventurer. Electrician.
      Find out why...It's About the Ride.
      • CMA1
        • Jul 2003
        • 114
        • Ontario, Canada
        Thanks Dragonrider!
        '79 Special
