Improvement for hard bag lid
  • Bartman
    • May 2012
    • 200
    • Jefferson, Georgia
    Last year I lost one of the lids to my hard bags. I purchased another and painted all parts this summer. But I didn't trust the locking latches and wouldn't put the lids on until I came up with a (better) latch.
    I decided that if the front was a hinge then if the back wasn't hooked that the lid couldn't fly off. But I wanted to be able to remove if necessary.
    I found a open hinge that seems to be the ticket!
    Take a look and see what you think. I have new rubber trim that I need to put on next.
    79 XS11
  • Bartman
    • May 2012
    • 200
    They are called small detachable hook over hinges.
    79 XS11
    • Bartman
      • May 2012
      • 200
      Here is the other picture that I wanted to post.
      79 XS11
      • thumperjsa
        • Apr 2004
        • 546
        • Coconut Creek, Florida
        I like that. If I can get a hold of the hinges and a rivet gun I may try this so I stop losing lids. Only lost 2 in the past 7 years. Is there a source for those hinges that's preferred?
        Owned by a pair of XS11's. An 80 Standard and a 79 Special.
        • Bartman
          • May 2012
          • 200
          I remembered that in the US they are called take-apart hinges. About $3 for two sets. They don't line up with the old holes is the only thing I did't like.
          I got them off Amazon.
          I did put a small plate on the inside of the lid to spread the load.
          Take-Apart Hinge, Steel
          Product Information & Specifications
          Hinge lifts apart so lid or door may be easily removed.
          Steel base material.
          Joint length is 1-1/4".
          Open width is 1-1/8".
          Screw hole spacing is 3/4" both ways.
          Uses #4 pan head screws (not included but offered for purchase during checkout). Uses 4 screws per hinge.
          Finishes:
          Nickel Plated
          79 XS11
            • 9980
            A safety cable is a good idea no matter what hinge or latch you use.
            The inmates from the local detention center could care less what those hunks of ABS cam off of.
