Jet Kit for 79 xs1100F
  • phatts27
    replied
    Hey rev, I read a lot of good things about the k&n drop in. I'm on the same boat as you, reverting back to stock. I believe uni offers a filter for around $15, an oem will run you about $40 and a k&n will set you back about $55. I went with the k&n because I know I'll never have to buy another and it only cost a little more than oem. Plus, I'm a sucker for a good sales pitch: more hp, more tq, more mpg (we'll see)...
    Leave a comment:
  • TheRev
    replied
    So I assembled my airbox and will soon be in the process of going back to stock. So for those of you with the air box, what are you using for a filter? Is the K&N filter so much better than the uni or foam filters? I don't want to spend three times as much on a filter if I don't need to.
    Leave a comment:
    replied
    As SpecialEd runs a MAC, I would say go 1 up on the mains, and start from there. If you need to turn the screws out more than 2 1/2 times, go 1 size larger on the mains. IIRC, Ed has 1 up, and about 2 1/4 turns on his carbs. This is with a stock air box, K&N filter installed.
    Leave a comment:
    replied
    Start with stock.
    Leave a comment:
  • TheRev
    replied
    I would love to live in a place that I could ride all year long. It's -13 today in Wisconsin. My goal is to get these carbs to work well before May. Any suggestions on where I should start as far as the jets. I have a 2 in 1 mac exhaust.
    Rev,
    No. I didn't get to the carbs yet. I spent part of Sunday on the BMW, as it was 80F in the afternoon.... I'll get to the carbs in storage after work today, and let you know.
    Leave a comment:
    replied
    Sent you a PM. I have the slides! Let me know what else, if anything, you need.
    Nice!! Let's help getting that beautiful bike running as sweet as she looks!
    Leave a comment:
    replied
    Leave a comment:
    replied
    Rev,
    Leave a comment:
  • Orange4
    replied
    The easiest is going back to stock. The stacks in the stock airbox are almost 4" long. With those on there's not much room for a pod filter between the end of the stack and the frame. You could get fancy and build your own filters. Uni Filter sells it's filter material in sheets but then you are practically building an air box.
    BTW, what do you do with your crankcase breather when you run pods?
    Leave a comment:
    replied
    I know we have the same bike, but do u have the '79 carbs? Stock, you should have 137.5 Mains, and 40 Pilot jets(?). Start there. Plug chop come Spring.
    Leave a comment:
    replied
    Hey Rev- Gimme a sec, and I'll answer you.
    Leave a comment:
  • TheRev
    replied
    OK, so I have a air box that I purchased a few years ago. I think what I am going to do is purchase new slides and try to go back to stock. I have a feeling I will be chaising the tuning issue for a long time if I stick with the PODS. So here is my question. What jets should I start with if I have a air box and Mac 2 to 1 exhaust? Thanks
    Leave a comment:
    replied
    Honestly, between the lack of the airbox, pods, or whatever, versus your drilled slides, your airbox dillema should be the least of your worries. Do what you gotta do to get as-close to stock as possible.
    Leave a comment:
  • TheRev
    replied
    Do you think if I put the airbox back on i would be able to tune the carbs with the drilled out slide? Or to I need to purchase other slides?
    Leave a comment:
    replied
    Originally posted by TheRev
    Or perhaps I just need to buck up and use the damn air box with the stock jets.
    This would be ideal if you still have it. Pods (or P.O.D.'s as my new-to-biking buddy calls them), are over-rated in a street-riding application. Anybody using them for street use either lost their box, or was un-informed as to their application (racing). My 750 never had an airbox, thus pods.
    Leave a comment:
