Goop v. valve cover gasket
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Gents, I'm tired of waiting for a new valve gasket every six months or so when I bend a valve or two...or three. What is the preferred sealer for the cover? And does one just put a layer on the cover flat surfaces, including those little tabs that cover oil-filled holes in the head?
    • 3956
    Hey! I use "The Right Stuff" by Permatex. However, getting that valve cover back in after using the sealant is a chore.
      Yamabond, Right Stuff, any ol' RTV sealant. Which ever type floats your boat.
      Small bead along the entire sealing surface.
      • James England
        • 3039
        • North of England
        335 builders' silicone from a mastic gun....
        • TADracer
          • May 2006
          • 1417
          • Kenner, Louisiana USA
          I personally like the Yamabond. No reason in particular, I just do. And yes, the shelf life of the opened tune is a lot longer than the three months they have on the label.
          But like a paint job, it is the preparation that will count. Make sure both mating surfaces are absolutely pristine. Check the half-moon plugs on the right side of the head for their viability and seal them in their pockets with some of your chosen sealant. If you are using Yamabond, spread a thin layer on all the gasket mating surfaces and spread it out with your finger so it is very even and there ate no gaps at all. make sure you have enough room to insert the valve cover directly down on top of the head. Tighten using a center out pattern and immediately remove anything that might squeeze out.
          Do that and you should have no leaks and it will last until you need to remover the cover again.
          Mike Giroir
          79 XS-1100 Special
            • 1987
            I guess
            I am old school. I still prefer a gasket. A small amount of oil on the surface before installation keeps it from sticking and the cover can come off and on several times until the heat makes it brittle. Unless you have a leak with the gasket you don't need to use any bonding agent with the gasket. I am not disagreeing with anyone on the use of the RTV etc... just not something I do.
            • TADracer
              • May 2006
              • 1417
              Actually, I am too and when I purchase gaskets I usually get two. But every now and then I don't have one and will fall back on the Yamabond. It works well to and will get me back on the road if my gasket fails while doing a tune-up.
              Mike Giroir
              79 XS-1100 Special
                Originally posted by TADracer
                I personally like the Yamabond. No reason in particular, I just do...
                Actually, there is a reason to prefer Yamabond; it 'flows' better than all the other silicon-based sealers I've tried. I've found that Yamabond doesn't leave a 'bead' where it squeezes out, but instead 'flows' onto the adjoining surfaces. Means that you should clean it off exposed surfaces after application and before it dries, but you won't end up with loose 'strings' of sealer inside the engine (or whatever you're sealing) like you would with 'regular' sealers. Great stuff... I find myself using it on any machined joint, bike, car, whatever.
                And I've mentioned this before, but it bears repeating; if you do delete the cam cover gasket, check for interference between the cam bearing retaining nuts and the cover; dry fit the cover, then move it around a bit, then look for scratches inside the cover. I've run into this several times, general pretty light interference, but sometimes there's enough to prevent the cover from fully seating until you tighten the cover bolts (risking cracking the cover). Some light grinding on the cover will clear this up...
                • mack
                  • 2411
                  • Ontario, Canada
                  Pam
                  Spray the gasket with Pam, it will last forever and not stick to either surface.
                  mack
                  79 XS 1100 SF Special
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  https://youtu.be/wB5Jfbp6SUc
                  https://youtu.be/RaI3WYHSuWA
                  Frankford, Ont, Canada
                  613-398-6186
                  • Diskman01
                    • Mar 2011
                    • 263
                    • Sioux Falls, SD
                    I used a tube of "The Right Stuff" and beaded the valve cover then stuck the new gasket on the cover. Carefully installed it on the engine and re-torqued the valve-cover bolts a few hours later.
                    When I re-did my valves last month, the gasket was still attached to the cover, but came off perfectly from the head. Was able to clean up with carb cleaner and re-install the cover just fine. No leaks.
                    I even bought a new spare gasket just in case.
                    Yamabond on the cover side to hold the gasket would work also.
                    1) Fire up Internet Explorer
                    2) http://www.yahoo.com
                    3) type "www.mapquest.com" into the Yahoo search page.
                    4) go about day as VP managing multi-million dollar financial contracts.
                    • LoHo
                      • Sep 2002
                      • 1342
                      • Fresno, CA
                      Yeah, I was wondering if bonding the gasket to one surface and Pam-ming the other side would work. How many of y'all do it that way?
