Help, both something wrong and I'm an idiot
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    Just for interest's sake, you could take off the valve cover, remove the cams (being careful to tie up the cam chain so it doesn't drop inside the motor), and perform a leak-down test. With the cams out, the valves should all be closed, with even the bent one(s) closed enough not to hit anything when you rotate the crank to bring each piston to TDC for its test. A leak-down test will give you an idea how many valves, and whether intake or exhaust, before you remove the head.
    Ken Talbot
      Originally posted by red bandit
      If you turn it over gently you won't bend any.
      That is not a true statement. You don't realize the amount of leverage a piston has at the top of it's stroke and how weak a valve stem is. My very first time to do this type of thing to one of these, I got the cams in time with the crank, then very very carefully, I rotated the crank with a wrench. The cam chain was running beside the crank, not on the crank gear, so the cams never moved. I was busy watching the crank timing. I bent several valves and never felt a thing.
      A valve just a little bit open and an ever so slight kiss from the piston.. bent valve. A valve pushed all the way open.. locked up motor and severely bent valves. Probably cheaper to find a used head than buy a handful of replacement valves. But... better still to get in there to examine what's going on.
        Just curious... Why do you worry about TDC when you're just doing a leakdown test? It shouldn't matter where the piston is just as long as it's still in the cylinder.. lol.
        I'm just concerned with moving this motor any more until the head is off. After the head is removed, I usually stand up the head on it's edge.. either on the exhaust ports or the intakes, with a set of the ports straight up. I pour a small amount of gas into the port and check for leaks around the valve. Turn over and repeat for opposite side. Very small seepage can be fixed with lapping compound. Valves that have quite obvious amounts of fuel running out around them need to be replaced.
          +1!........on top of fact that it was spun over with the starter......agree that a known good head/valves is best option.
            • 8077
            There are motorcycle mechanics out there making a living working on old bikes in little shops, often their own garage. I know several of them. Mechs like that may not know every nuance of an XS1100, but many of them can find a manual and read it, and get an old bike sorted just fine. No offense intended towards Mr. Pain, but some folks shouldn't be dissuaded from taking their bike to a qualified mechanic.
              While there is truth to what you say, Marty, how many times have we heard good stories about people taking their bikes to mechanics on here vs horror stories? What seems to happen most of the time, is people take it to a mechanic, they don't fix it, they charge the person large fees, then they are essentially right back where they started, minus some weight in the pocket book.
              It happens often enough that I think the dissuasion is warranted... even though yes, there are some good mechanics out there for those with more money than time.
              • Ken Talbot
                • 4251
                • Revelstoke, BC
                You're absolutely correct. With the cams off, it really doesn't metter where the pistons are for a leakdown test.
                ... gotta disengage the brain autopilot more often....
                Ken Talbot
                  lol.. Not a problem, Ken. Was just asking.
                    • 9981
                    Depending on cylinder wear and WHERE the wear is, TDC would be the best place to check it since that would be the highest point of compression. Just my $.002.
                    • Pain
                      • 476
                      • Milwaukee, WI
                      None taken. I aware aware of my limits when wrenching, mostly because I am constantly stretching them.
                      I have a lot of faith in my mechanic (The Shop in Milwaukee), and have been using them for more than a decade. They aren't cheap, but they stand by their work.
                      The current plan is to replace the head, which I'll be doing later in October, since I have a couple events before then which will take up my time. I'll share, when the time comes.
                      I've been in more than one Hemisphere, and I wrote a book to help you do it too (or just prepare better for that week long road trip). Going Small, not just for the little guys.
                        • 8077
                        Your shop appears to be a place with the resources to keep an XS1100 going. A place like that doesn't last if they can't turn out a good product. You have to understand, a lot of folks have had bad experiences taking an XS1100 to a professional. I've had errors made on mine when I turned it over as well, but overall my experience with the old time bike mechanic has been good. These days, I'm doing my own work.
                          • 6765
                          Back in the day before I discovered this forum...I would always take my XJ back to the service dept of the dealer I bought it from. For many years their Service manager worked on my bike and all was well...then at some point in the 1990s they no longer could or would...one of the salespeople had started his own bike shop and the service mgr referred them to me. They would only work on older bikes. I became friends with their main mechanic and he knew these bikes inside and out....most people though are not that fortunate.
                          2005 Honda SilverWing 600
                          2018 Honda PC-Xpress 150
