aftermarket seat pan install ?
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    I bought an aftermarket fiberglass seat pan and the accompanying install kit. Install kit is 4 mounting blocks and a flat wooden pan to mount the seat pan to.
    After mocking it up, the seat pan is about 3/4" too high. Meaning it does not make contact with the mounting pan...it's floating above it.
    I have 2 options:
    1. I add 3/4" piece of wood as a spacer to make it work OR
    2. Cut off about 9" of the frame where the blinkers mounts. Since I'm not using the rear fender, I don't need this material. This will allow the seat pan to sit flush w/o any additional spacer. (I'm using smaller aftermarket blinkers too which can mount elsewhere.)
    I'd like to go option 2, but I'm nervous about making the cut.
    Thoughts?
    Thanks!!
    Rob - 79 SF
    • 8054
    How To Mount a Cafe Racer Seat in 5 Minutes for 5 Bucks
    DCC-Tech Tip: Installing a cafe racer seat -no welding
    Google it until you see something that works.
    • mrhammer2u
      • Aug 2014
      • 472
      • Northern, NJ
      Hey Jet. Thanks! In the 1st, the tail light section of frame is cut off.
      In 2nd, that's the kit I have,..but the seat pan does not sit on that flat wooden piece because the frame is in the way. So I can either add more spacer or cut the tailight section of frame off.
      Advice from here?
      If I chop frame, what do you guys fill the hole with?
      Rob - 79 SF
        • 8054
        Some of these places sell frame loops. You cut the frame and weld a loop in its place. Watch the video. You might want to just raise the whole thing with some square tubing.
        • mrhammer2u
          • Aug 2014
          • 472
          • Northern, NJ
          Thanks again Jet. I just contacted him about the appropriate frame hoop I would need. I will also consider just a flat straight piece of metal to weld on, or caps if I can find something to match up.
          Will be done this weekend. Thanks!
          Rob - 79 SF
