Hey Done,
The Valve seals are just rubber, and with the combined heat/and age these engines have seen, they can harden and then leak, but have otherwise no affect on the pistons....except that if they are/were leaking....if it's the intake, then you can get oil fouling of the plugs....if it's the exhaust, just smokey exhaust. Still don't think it's a valve seal though, but as has been suggested, valve cover gasket on inner side leaking down thru head vent hole to the cylinder/exhaust flange/bolt. Just hate to see you go thru all the work to tear into the head to replace valve seals that may or may not be leaking.....however you will also remove the valve cover and then hopefully reseal it with new gasket/sealant...and so will end up fixing the suspected valve cover leak anyways....but may think it was the valve seal that got fixed!? YMMV.
