Another milestone in the rebuild
  • RichV
    • May 2013
    • 374
    • Everywhere
    Today I got the cylinders off the engine of the second bike. A few more parts removed and the engine can come out. At that time, I can start moving everything from the old frame to the new.
    Anyway, I used a hoist to help remove the cylinders and this time it took only a day of hitting it with a hammer. Big change from last time I did this (2 weeks).
    The constant tension from the hoist and half a can of PB Blaster did the trick. I also used a single edge razor blade to "break the seal". I tapped it into the grove a short distance and it expanded it enough for it to start pulling apart. I also hit it a lot with a rubber mallet and used some wood blocking for leverage.
    I had the very same problem this time with corrosion around the studs. The forward studs between 1-2 and 3-4 were badly corroded at the top. The forward inner studs had corrosion near the base which made the very last part very difficult.
    After removal of the cylinders, I checked the bore and they were even and in specs with a very low variance in width between top and bottom (within the margin of error). The piston rings also look in good shape.
    Here are some photos.
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Looking good. As always, if you some local assistance TC and I a just a short ride away.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • RichV
      • May 2013
      • 374
      • Everywhere
      I'm actually starting to feel good about this build. The engine I had leaked at several points so I was worried that the cylinders/pistons were bad.
      Things should go a lot quicker now.
      Also have:
