Bigbore kit for xs1100?
    IIRC, it has the stock exhaust..........and flow characteristics have proven on here not be any better than stock.
      • 9981
      It has been broken and repaired repeatedly and leaks.
      You know as well as I do Brant that ANY engine can be tuned to run very good with pretty much any exhaust, except open pipes.
        Very true Greg! I was referring to not to expect any performance GAINS using anything but stock.
        To bad about the stock system not being perfect. Still an overall good lookin' bike though!......least from the pics posted.
          • 9981
          He needs a good stock Special system for it if you run across one.
          • MPittma100
            • Aug 2011
            • 2359
            More XS11 Horsepower
            Lot's of ways have been mentioned to make more horsepower. Problem is that the more horses you have, the more they eat.
            By the time you did big bore, carburetor, cylinder head, camshaft, and exhaust mods, you would have a ton of money and much effort in the bike. Probably be tuning it forever.
            You would end up with a bike that only wanted to go fast and probably would not have anything in between slow and fast. So there goes driveability and gas mileage. Not to mention what you may tear up in the drive train.
            If you are not satisfied with the 95 HP that you already have. And you don't want to lose all those other things, then maybe there is another idea to gain horsepower and keep the bike pretty close to stock.
            I'm thinking..................................NITROUS OXIDE!
            As a rule you do not want to add more than 1/2 of existing HP with N20. 95+47.5=142.5 HP total. One should get some pretty good adrenaline rushes with that much sudden kick?
            Question is.......Who makes a kit for a bike? Surely someone does. Might be worth looking into. Just saying.
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • XJOK2PLAY
              • 2099
              • Skiatook, Ok.
              Originally posted by BA80
              The 78 and 79 engines are quicker than the 80 - 83 and they have smaller valves.
              That engine doesn't run any better than the stock 79 engine in my bike. I rode with Russ a lot when he was on that bike. 97cc doesn't make much difference in the grand scheme. The Navy Bike has also been converted to the 2H7 TCI and has a centrifugal advance. It would run a lot better with a good exhaust on it I think
              Well.......guess we'll see in a few weeks from now?
              You planning to ride the Navy bike to NC, right?
              Maybe we'll have to see how well it runs out on the way there....huh?
              2011 Kaw Concours 14 ABS
                • 9981
                JW has The Navy Bike. Try and keep up Bobby.
                We are meeting him in Little Rock.
                  • 9981
                  MP
                  Seems that could be plumbed right into the existing vacuum ports on the intake boots fairly easily. The problem would be a place to put the tank and the controls.
                    Was my thoughts also BA80.........hell, just strap the bottle on passenger portion for a quick occassional thrill
                    • XJOK2PLAY
                      • 2099
                      • Skiatook, Ok.
                      I know that, Greg.
                      I was actually talking to him... Not you.
                      When I quoted it, it was supposed to have his comments, where he was bragging on it.
                      Sorry for the confusion.
                      • MPittma100
                        • Aug 2011
                        • 2359
                        N20
                        There is a small bottle ("Sneaky Pete"). A kit would need 2 solenoids - one for fuel and one for gas. Don't know if the system could be run on "gravity" fuel. May need an aux pump. A system may not be too hard to assemble?
                        MP
                        K&N Air Filter
                        ACCT
                        EBC Front Rotors
                        Mike
                        • Prisoner6
                          • Aug 2013
                          • 1184
                          • Phoenix, AZ
                          Well ...
                          Nitrous has been done on the XS11 ...
                          Here is one example:
                          And here is the story behind it:
                          Marco
                          1979 Honda CBX
                          2002 Kawasaki ZRX1200R
                          WE MISS YOU, DON
                          • Prisoner6
                            • Aug 2013
                            • 1184
                            • Phoenix, AZ
                            Also,
                            James (member JamesEngland) had an XS11 running with nitrous. See his posts #6 and #12 in the thread below:
                            Maybe James will chime in on this and tell us more??
                            Marco
                            1979 Honda CBX
                            WE MISS YOU, DON
                              • 8062
                              Is that Pee Wee's bike?
                              Yes, it is.
                              • James England
                                • 3039
                                • North of England
                                I ran an XS1100 with nitrous for over a year. I had 50bhp jets in it, although I started out with only 25bhp but rapidly went for the bigger ones. I used a complete kit which is still manufactured in the UK.
                                The XS11 is ideal for nitrous because of its unconventional drive train, with 'backwards' rotating engine and the shaft drive. It makes it almost impossible to wheelie due to the nitrous kicking in. What happens is that when the nitrous is activated, the swing arm pushes downwards onto the road and the back end of the bike lifts, rather than having the front end lift up, wheelie and effectively lose the nitrous power on the front raising up off the road.
                                Nitrous is either completely off or completely on. It's meant to kick in at full throttle openings and is activated by a micro switch on the mechanical side of the throttle so that as soon as full throttle is reached, the cable-operated lever clicks the switch.
                                There are two solenoids, one for fuel and one for the nitrous, plumbed into the inlet manifolds with colour coded lines to avoid confusion, with the fuel injector closer to the engine, so that the blast of the compressed nitrous adds additional 'push' to the fuel into the engine.
                                I mounted the bottles (two small fire extinguishers) at the rear of the bike from the US indicator mounts which are usually blocked off with grommets on European models. I painted them black to avoid undesired interest from following police cars.
                                The fuel taps MUST be modified to give full, gravity-fed fuel at all times, by drilling them out internally. A fuel pump is NOT advisable, as it could fail. Gravity fuel flow is more than adequate. Effectively, the taps are on full flow permanently and the 'off' diaphragm vacuum aspect of them bypassed permanently. This is vitally important with nitrous because, in the event of fuel starvation due to inadequate flow, or the failure of any fuel pump unnecessarily fitted, the nitrous oxide will act as a cutting torch and literally cut through the head or valves or pistons. Fuel starvation means a guaranteed engine destruction. For this reason, the fuel and nitrous solenoids must be absolutely top quality and wired into the electrical system absolutely securely and via un-fused wiring. They can be connected so that the nitrous solenoid will only operate if the fuel solenoid is active. Otherwise, failure of the nitrous solenoid means a super rich fuel intake with fuel going through the carbs as normal and fuel being injected into the manifolds too...not disastrous. Failure of the fuel solenoid however, means fuel starvation which will equal new engine. Cheap nitrous kits are therefore to be avoided at all costs.
                                When using the nitrous, the system is first armed using a bar-mounted master switch. This activates the system and allows the micro-switch to operate both solenoids at full throttle. The nitrous is meant to kick in when the normal carburetion is struggling, not when it is doing its normal job, as it were. You do not want nitrous kicking in at even mid throttle openings.
                                I fitted heavy duty clutch springs only and never had clutch slip.
                                When it kicks in, the effect is instant. My first use was as I overtook a car. The back end of the bike rose to full extension of the shocks as the swing arm was forced onto the road, and I thought the clutch was slipping as the revs rose immediately to red line. It wasn't slipping and, when I looked into the mirrors, I saw the car I'd overtaken about a quarter of a mile behind me! That's was only with 25hp jets. With the 50hp jets, the effect is even more mind-blowing.
                                On a Dyno, my bike accelerated from 60mph to 120mph in approx 2 seconds.
                                Nitrous oxide is extremely cold and the engine actually runs cooler when it's operating. It's also very smooth power delivery and not at all uncivilised (apart from the sheer speed).
                                I ran mine through loads of gas refills for about a year, with no adverse incidents of any sort. The place I bought mine from (still in business here in the UK) said they often increase the bhp by 75% over original and even 100% on lower mileage engines in perfect order.
                                Nitrous refills are cheap enough and I got mine filled locally via a hospital supplier.
                                The UK manufacturer was looking into using the frame of the bike as a storage system for the nitrous, although I don't know if he ever achieved this.
                                As a mod, nitrous is good in that it does not affect running when switched off, unlike high-lift cams or similar. It also achieves results which are completely impossible by normal tuning methods. Standard airbox and filter can be used (I did). There is a less drastic option of putting the jets into the airbox instead of the manifolds but it's not as awesome.
                                I loved it......
                                BTW UK insurers will accept the nitrous being fitted, on the understanding that it is never used......???? Err...right....I'll fit it but never use it, right?
