For Those Who Run Irridium Plugs . . .
    • 4015
    Looking to finally installing them tomorrow. I read that brass inserts are used in-place of the resistors in the caps. Is the brass something I can find @ Home Depot, or hobby shop only? I think we have a Ryder's here.
  • James England
    • 3039
    • North of England
    I just put thick copper wire in the ht caps. I've also wrapped silver foil around the original resistor and put it back in. Both methods work fine..
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Anything wrong with just using the NGK 6637 as is ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • James England
        • 3039
        • North of England
        HT caps have a built in, removeable resistor but iridium plugs have a resistor already inside them. I removed the resistors from the HT caps and replaced with copper wire in order to get a bit more oomph to the plugs...it seemed pointless having two resistors in series before the power gets to the plug..
          • 4015
          Here: http://www.xs11.com/forum/showthread...park+plug+caps
          http://www.msdignition.com/page.aspx...erms=Why%20MSD
            • 4015
            Btw, as posted in another thread, I replaced the resistors with solid core copper wire from Home Depot. Not sure I notice any difference between the two plugs.
