Kinda stumped here. Got an 81 xs1100 special I'm working on for a buddy. Idles great, runs great, rips up the highway. Problem I'm having is if your cruising along and give the bike half to 3/4 throttle, it will "hiccup" almost like you loose all power for a half a second then it kicks back in and goes. I you start in first and dump the throttle through all the gears it goes like a rocket with no problem. If you gingerly granny shift through the gears its fine too. Its most predominant when your just cruising a back road at a steady pace and want to just goose the throttle a bit to speed up a little. It will jerk for half a second and then go. Doesn't matter what gear. But seems less likely to do it if you ease into it. If you whack the throttle it pukes for half a second like someone flips the key on and off. No backfiring. No increase in rpm like a slipping clutch. I was thinking coil but I'd think it would act up more under heavy load. Any ideas? Where should I start looking? Bike has been ridden all sumer with no issue this just started.
.... .at this point, keep the hands away from the carbs.......seriously
