So first of all I want to say that my budget is pretty low which is why I haven't just replaced the carbs.
I think you can see by the images what I'm up against.
So far I have tried JB weld and some good old fashion electrical soldering. But all just pop out. The initial drilling was at 1/16th which as I found out later was WAY over what it should have been. I went into the Dremel area in homedepot and found a 1/32 which I found to be the same size as the other holes.
So my question is what can I use to fill it in and then drill the correct hole size?
more work to do this Spring!
if I could close it up just a hair it would make a HuGE difference.
