Newbie to the XS with Questions
  • Doo-Daa
    • 53
    • Amarillo, TX
    I'd like to say "Hello" to all, and to let you know that because of this forum, last Friday (4/23) I purchased a '78 XS.
    First a bit about the bike, the second my question.
    78, XS, 11,060 miles on it, bought from the original owner, pristine, garaged all the time, 3 years ago went in for about $1000 of work (at the dealer he bought the bike from)(new tires, Carbs cleaned, new Battery, new fork seals and oil, replaced all the fuilds, and tune-up.) Other than the obvious, I don't know the specific reason he did the carb overhaul. I can speculate that
    since he hardly rode it, he thought the carbs were gummed up and had poor performance. After all that work, he's ridden it about 50 miles in 3 years. I don't think the dealer fixed his problem and he became frustrated. At the time of sale, all he could do was complain about the carbs.
    Anyway, it started, but was obviously running on only #2, & #3. Following different posts, I figured the pick-up coil issues talked about would cure most of the mis-firing.
    Now to the problem:
    First what I've done, (I consider myself a fairly good wrench, and by the constant stream of mechanical devices through my garage, others do also)
    Changed the oil, new plugs, (Previous owner had put Stabil in the tank), cleaned the tank and found no problems, fixed the pick-up wire,(it was broke), disassembled #1 & 4 carb (on the bike) by pulling to top cover, and bowl. Didn't touch the floats, but everything else was pulled and cleaned (jets, emulsion tubes, all of it) Carb cleaner thru all of it and found no sludge, dirt, or varnish. Cleaned air cleaner, and checked for critters in the intake tubes.
    Fired right up, and in the driveway, ran on all four for about 2 minutes. Found the plugs completely fouled. Replaced plugs, and started up and ran. Synched the carbs at 1000rpm, and got all of them at 6" vac, but the vacuum advance plate was oscilating quite a whole lot (About 1 1/2" of travel at idle, no wonder the wire breaks). And I was getting some poping back into the intake tubes. Checked the valve train the next morning and found the clearances to be a bit tight, about 1/2 of what the factory manual says, but they're all consistant, and I don't have any reason to suspect the shims have been changed.
    Anyway took the beast out for a ride to test my progress. Wasn't good. Went great for about 3 miles, then bogged down to 20mph, and no manipulation of the throttle would do anything else. Ended up about 6 miles traveled, and used near 3/4 of a gallon of gas. Heavy black smoke out of both pipes, plugs fouled, and removal of the air cleaner didn't change anything.
    This is where I'm asking for help.
    Do I need to do a complete tear down of the carbs? Could the enrichment circuit be "misadjusted" and dumping fuel? Floats to high? I don't understand how a CV carb can dump that much fuel. And do it to all four cyclinders.
    Any help or experience you can lend would surely help.
    A frustrated
    Doo-Daa.
    It sounds like the vacuum advance is hooked up to the nipple on one of the intake manifolds instead of the nipple on the body of carb #2. This will cause undampened vacuuum pulses which have the advance swinging all over the place. Then, I would speculate that there's yet another break in that set of pick-up coil wires. Wild fluctuations could certainly cause more than one break.
      • 5058
      1. Check out the condition of the exhaust system. Especially look for cracks under the heatshields near the front pegs. I dare say that the welds give the specials the most problems. Check out the baffles as well. Do not mess with the carbs to "counteract bad exhaust...it will not work!
      2. The pick-up wire thing should be checked for bikes before 1981. The wires can act-up when they heat up, making it seem like an intermittant problem. I suspect that this is not your problem since your plugs are fouled and not wet. It will usually affect firing in pairs, like No. 1 and 4, or, No 2 and 3.
      3. Make sure that your float(s) are not sticking open, thereby flooding a carb.
      4. Make sure that your filter is not filthy. You said the same thing happened with the filter removed, so I you can rule this out.
      5. Make sure that if you have older model carbs (78/79) the breather tubes from the carb pairs are connected to the nipples on the airbox and make sure that the airbox nipples are filled with plastic. This could happen if your bax came from a later model bike. If it is the correct airbox, make sure that the "manifold" for the breather nipples is not plugged-up.
      6. There is a centrifugal advance on the engine-side of the pick-up coul plate. Make sure it is lubed and not sticking.
      7. And finally, make sure the carbs are in good shape. (welcome to carb hell)
      7a. Make sure the carb passages are clean.
      7b. make sure the float pins are not corroded and causing restrictive movement.
      7c. Make sure the float levels are OK.
      7d. Make sure none of the floats leak.
      7e. Make sure the needle valves above the floats are sealing OK and that the needle springs are functioning and not stuck inward.
      7f. Make sure the main air jet in the inlet bell is clean. This jet is pressed-in and is very small.
      7g. Make sure the slides have free motion and are not sticking open.
      This is all I can think of.
        • 5058
        No 5 should read,
        5. Make sure that if you have older model carbs (78/79) the breather tubes from the carb pairs are connected to the nipples on the airbox and make sure that the airbox nipples are NOT filled with plastic.
        • CA.XSer
          • 188
          • Jerome, ID.
          Make sure the idle jets are the correct ones, they should have six(6) holes on the sides. If the PO had the carbs done and the dealer put in K&L kits,
          Gary
          79sf
          78e
          • DEmily
            • Jun 2003
            • 220
            • Kansas City, MO.
            I agree with CA. I just and hour ago sitched the K&L pilot jets with the originals and the BIGDOG runs like new!!!
            79 XS1100 f (BIGDOG)
            80 XS650 Special
            85 KAW 454 LTD
            Dirty Dan
