Low beam on the Venturer headlight.
  • stereomind
    • 109
    • Tulsa, OK
    Really.. Is this a joke? I can barely see the headlight beam on my garage door.. In the dark.. With a brand-new bulb.. What gives?
    High beam is pretty decent.. The bulb is seated properly, and locked in place.
    I guess I'll check voltage going to the bulb tomorrow, to make sure it's not a supply issue. Or maybe I'll just stick a rack of four KC lights on top of the fairing, and pretend I'm a Jeep
    peace
    Vlad
    '81 XS1100SH "Hound of Basketville" - new project
    '81 XS1100H Venturer
    '81 XJ750RH Seca
    Yeah, start with checking the voltage. If that is good then the problems if going to be the reflector in the headlight lens. The silvering is not of the greatest quality. Best thing to do is this:
    • stereomind
      • 109
      • Tulsa, OK
      Neat! I may have to try this mod... Thanks for the info.
      73's,
      KD5WUB
      http://www.xs11.com/forum/showthread.php?t=33251
      '81 XJ750RH Seca
        I had that issue before too Vlad. Check the connections behind the fairing where the wiring connects to the fairing pigtail, check connections where the pigtail plugs into the fairing and all connections inside the fairing. That's where the problem most frequently is.
        There's also the switch and it's plug and the reserve lighting unit. It's just a poor connection somewhere and you gotta find it.
        • stereomind
          • 109
          • Tulsa, OK
          Yeah, I took a peak in the fairing pockets last night.. A monkey could have wired it up better. It seems to only affect the low beam, so first I'll swap the low and high beam leads, and see how the low beam behaves. That should tell me if it's the headlight itself or the wiring. I'll dig into it tonight after work.
          peace
          Vlad
          '81 XJ750RH Seca
            A dim headlight is usually indicative of a bad ground.
            • stereomind
              • 109
              • Tulsa, OK
              True, but wouldn't the high and low beams share the same ground?
              Vlad
              '81 XJ750RH Seca
                Yes, they do. However, it may not be as noticeable on high beam.
                That may not be the problem but as I said the ground is the usual suspect
                • stereomind
                  • 109
                  • Tulsa, OK
                  At this point, every wire on that bike is suspect. The PO, a supposed bike mechanic, has either not given a rats ass about the bike, or just isn't a good bike mechanic..
                  Vlad
                  '81 XJ750RH Seca
                    Vlad
                    Your suspicions are well taken and totally valid!........Good to hear SOMEONE not attacking carbs 'first crack out of the box'.
                      Hi Stereomind,
                      I am on the same quest for more light from the headlight.
                      My plan is to start with the Kill Switch on the handlebar to be soaked in Evaporust this week end. Your comment on the fairing wiring has given me another area to add to the list of connections to clean and check or is it check and clean
