Help!?
  • JerseyJon
    • Feb 2012
    • 180
    • Teaneck, NJ
    Help!?
    I can't tell you how grateful I've been over the years to you guys. But now I have a little bit of an emergency. I'm stuck in Jersey City, my SG is running beautifully, but the headlight and gauge cluster won't go on. It's nighttime. I still have the old fuses, and I replaced each one in order. The light didn't come on. I know the headlight stays off until the alternate her is generating enough juice. But I don't think that's the issue here. Any thoughts? suggestions? I carry the standard set of handtools.
    Hill? What hill? I didn't see any hill! Why wasn't there a sign? And where are my keys?
    80sg
    mods to come
  • JerseyJon
    • Feb 2012
    • 180
    • Teaneck, NJ
    By the way
    Which one of the four old style Fuses in the old-style fuse box is the fuse for the headlight engage cluster?
    80sg
    mods to come
      • 8894
      It is probably your headlight relay that bit the dust. It can be bypassed by unplugging it and jumping the blu/blk and the red/yel in the harness connector. By all means check the 10A fuse first, not sure where it would be located in the original fuse block though.
      • JerseyJon
        • Feb 2012
        • 180
        • Teaneck, NJ
        Thanks
        I checked the 10 amp fuse. That doesn't seem to be yet. Could you describe where the headlight relay is? I hate to be such an ignoramus. But you know.
        80sg
        mods to come
          • 8894
          It sits above the ignition coils under the fuel tank, front center, unfortunately the tank has to come off to access it. It has a 4 wire connector on it.
          • JerseyJon
            • Feb 2012
            • 180
            • Teaneck, NJ
            Ok.
            Lemme give that a try
            80sg
            mods to come
              • 8894
              Yep, when you find the small square unit, just unplug it and jump the red/yel + blu/blk wires and your headlight should come on with the key on position. GL
                Hey Jon,
                You're probably busy working on it right now, but hopefully you'll check back here before hitting the road to get home. IF you get the lights working, I would suggest finding a service station, or even a WalMart and get a voltmeter just to check to make sure that your charging system is still working, getting ~14 or so volts at 2500+ rpm at the battery. IF so....then you know the bike shouldn't die on you on the way home by draining the battery running the bike/headlight! Yes, Good Luck!
                • JerseyJon
                  • Feb 2012
                  • 180
                  • Teaneck, NJ
                  Made it!!
                  You guys never cease to amaze me with your generosity and knowledge. Here's what I did:
                  I didn't have a socket wrench, so I wrestled for about 10 minutes trying to get the seat off with an adjustable wrench. I could tell I was going to ruin something. So I gave up on that. I did, however, have one of those connectivity testers. You know, the little probe with the alligator clip that you hook to a ground so you can tell if a wire is hot. I opened up the headlight bucket and used that to find a hot wire and I just used some spare wire to jump from one of the two large brown wires going into a four prong connector to the green wire going into the headlight plug. I taped it up with electrical tape so that it would hold for the 30 mile ride home. And it did!
                  The highbeam didn't work, I assume that's because the highbeam runs off the yellow wire that goes into the headlight plug. Tomorrow, I'll check the wiring diagram to see what exactly I did, and I'll fix it.
                  Once again, Phil, TC, and everybody else here, I'm so grateful. Thanks again.
                  80sg
                  mods to come
                    • 8894
                    Good thinkin' there Jon, glad you made it there safe.
                      To paraphrase a prominent commercial,
                      "What's in your bike's toolkit"? The OEM one provided both a spark plug wrench, and I think it also fits the long seat nuts. BTW, there's also a MOD in the tech tips about converting the seat lock down nuts to bicycle/fold over pinch levers or whatever they are called so that you don't have to have a wrench. Glad you were able to shed some light on the problem, and was able to make it home safe and sound.
