Need help in Idaho please
    Was just an FYI Greg
    XSSE........I'll be close, next week in a cage to Columbus, GA........but that don't 'hold water' either..........guess it'll be next year.......com'on up......free lodging and you can't beat the weather and scenerey with a stick, least not this side of the Mississippi.
    May even decide to host a killer MOM and riding rally.......right out of my house/mancave/large backyard for tenting......JAT.
      You'll be pretty close to Jeff, Marty, Mike, and Brent. You might want to let them know you'll be around.
      I'm from Montana my friend and I've been all over. Colorado is nice but I've never seen anything to beat western Montana.
      All for a M.O.M., as long as there' lot's of riding mixed with the wrenching.
        Originally posted by cajun31
        at this point in his trip weather is going to be more of a factor then problems with the bike. Sounds like mechanically he is going to get there but looking at the weather today he has probably encountered quite a bit of rain. Hopefully the tires he has on the bike presently are able to handle it.
        I hope he's alright with the tires too and sticky/contaminated brakes aren't any fun in the rain either.
        The rain's the main reason I asked Billy to check the voltage at the Ignition coils, that's sort of how I wound up with Accel 3.0 Ohm coils and no more Ballast Resistor.
        Thirty years ago the Ballast Resistor on his Midnight Special was a shiny sealed unit but if it's gotten even a little water in it from rain or washing then it'll slowly deteriorate. Eventually the engine doesn't just snort, spit, cough, hack and stumble at low speed and off-idle, it makes spectacular backfires and flames shoot out the exhaust and then it won't run at all.
          I think motoman is on a mission. From me to Columbus is 3 hours if no traffic and Atlanta is in the way. The others are closer, but not by much considering Atlanta traffic. It would be nice, but c'est la vie.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            #95
            "I reject reality and subsitute my own"
            The fuel level in the bowl has a direct effect on F/A ratio. Having a low level in the bowl will only create a lean condition.
            Liquid fuel is fed to the nozzle of
            the carburetor venturi, and flows
            due to the vacuum generated by the
            air flowing past the venturi itself,
            and from airflow pulsations generated
            by the piston movement. The
            calibrated jets placed upstream of
            the spray nozzle itself control the
            fuel flow reaching the spray nozzle.
            Motorcycle carburetors are nearly
            always of the needle type and have
            a structural architecture as shown
            in the accompanying illustrations.
            The fuel arriving from the tank is
            held inside a constant level float
            chamber. The liquid pressure head
            on the various jets is relatively constant.
            The difference between the
            float chamber fuel level and the level
            that the fuel must be raised to
            by the inducing vacuum remains
            constant. The float chamber level is
            kept constant by means of a fuel inlet
            valve, actuated by a float that
            follows free surface of the liquid in
            the float chamber. When the float
            chamber level drops, due the fuel
            used by the engine, the float drops
            and opens the valve, so that additional
            fuel can flow from the tank.
            The level of the fuel and float then
            increases, and at a certain point,
            closes the valve until the sequence
            is repeated. The level in the float
            chamber is therefore a calibration
            element of the carburetor, since the
            metered fuel delivery changes with
            float level, and therefore affects the
            mixture ratio. By having a high
            float level, a greater fuel quantity is
            delivered compared to the case with
            a low float level, under all operating
            conditions and for all of the carburetor's
            circuits. Adjustment of the
            float chamber level is affected by
            two elements: the weight of the
            float (or of the floats) and the configuration
            of the lever arm that connects
            the float with the valve. By
            installing a heavier float, the free
            surface of the float chamber liquid
            must rise before the float buoyancy
            force balances the increased weight
            making the float rise. The result will
            be a higher float chamber level and
            a richer delivered mixture under the
            same conditions. On the contrary if
            we install a lighter float, a lower liquid
            level will cause sufficient
            buoyant force to actuate the valve
            and therefore the carburetor calibration
            will become leaner. That is
            why floats are classified according
            to their weight (printed on them)
            and calibration standards for their
            position inside the float chamber
            are prescribed in order to assure
            correct operation. To modify the
            float chamber level, if necessary and
            when it's not possible to change the
            Checking the position of the float inside the
            float chamber is prescribed. According to different
            carburetor models, the distance of the float
            from the contact surface of the float chamber
            needs to be measured float weight, in some cases it's possible
            to change the angle of the lever
            that operates the valve.
            In this way, the float closes the valve
            in advance (for a lower level) or
            later (for a higher level) at equal
            weight.
            We must note, however, that too
            low a level in the float chamber can
            result in an insufficient liquid head
            on the jets and therefore lead to the
            risk of dangerous enleanment of the
            delivered mixture.
            This can occur when the fuel moves
            inside the float chamber due to the
            accelerations the vehicle undergoes.
            In these cases (which mainly happen
            on off-road motorcycles or on
            the track, in the bends or under violent
            braking), if the level is too low,
            one of the jets leading to the carburetor's
            circuits may be temporarily
            exposed to air instead of liquid.
            In some versions, special screen baffles
            are applied near the jets.
            These are called bottom traps and
            their purpose is to maintain the
            maximum liquid quantity around
            the jets under all possible conditions.
            A needle that closes on a seat,
            which is inserted or screwed into
            the carburetor's body, forms the
            fuel valve. The needle is equipped
            with a synthetic rubber element on
            the tip.
            This material is perfectly compatible
            with normal commercial gasoline
            but in the case of special fuels
            such as those containing alcohol, it
            is necessary to verify the compatibility
            of the fuel and the seals in order
            not to compromise the carburetor's
            functionality.
            Different versions of the needles are
            equipped with a sprung tip in the
            connection with the float, in order
            to reduce the needle's vibration induced
            by the motion of the liquid
            in the float chamber and from the
            motorcycle's movements.
            The diameter of the needle valve is
            a calibration element since it determines
            the maximum fuel delivery
            rate.
            If the diameter is too small to accommodate
            the fuel quantity that
            the engine requires under certain
            conditions (generally at full load)
            the float chamber empties faster
            than it can be replenished through
            the needle valve! If this condition
            should continue for some time, the
            engine suffers from reduced fuel delivery
            due to the fact that the level
            in the float chamber is decreased
            and therefore the carburation has
            become too lean.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
              I had the same issue but packing the plug behind the fuse panel for the pickup coils with dielectric grease completely eliminated that problem.
              I think it might even run good under water now.
                Mine burned itself in half inside the shell; pulled over when it quit running and heard something sizzling under the sinister side of the tank. I jumpered it to get home and eventually dug the Accel coils out of the parts bucket -- ballast resistors! Ack! Ptooey!
                • BillyRok
                  • Aug 2011
                  • 421
                  • Shortsville, NY.
                  #98
                  One more day to go
                  I'm stopped in OH for the night, just missed the rain...for now, it appears. Tomorrow looks wet for sure, got 375 miles to cover. No choice but to take it easy and get there when I get there. No joy here with the wifi again so I'll have to do the whole trip update after I get back.
                  Billy
                    I was going to make a comment, then it occurred to me, weren't we trying to help a fella get his newly acquired bike across the country to home? He me have some trouble following this thread out on the road, or he's given up on us.
                      After
                      such an epic journey there surely is no need to push fate. Unfortunately the weather is not going to be cooperative at this point. Be safe.
                        Hi Billy,
                        Nearly Home Hope the rain manages to miss you. At least the weather is nice and warm between the showers.
                          • 3372
                          Good job Billy, you "Rok"!
                          2001 ZRX 1200
                          1982 Seca 750
                          1983 Nighthawk 550
                          • BillyRok
                            • Aug 2011
                            • 421
                            • Shortsville, NY.
                            #103
                            leaving at 4:30
                            Woke up early and radar looks good for now...a sign from the good Lord...I'm making a run for it!!
                            Billy
                            • BillyRok
                              • Aug 2011
                              • 421
                              • Shortsville, NY.
                              #104
                              Home!
                              Made is back and never hit a drop of rain! After my nap I'll try and get pictures posted from the trip.
                              Billy
                                • 3372
                                Awesome! Huge undertaking and what a feeling of accomplishment, you gotta be pretty proud of the bike and your effort too.
                                2001 ZRX 1200
                                1982 Seca 750
                                1983 Nighthawk 550
