Headlite problem?
  • DCracer25
    • Jul 2011
    • 179
    • harpursville NY
    Headlite problem?
    Ok got the trike out for a long run (81 1100 ) and was on my way back after dark on the highway when I switched from low beam to high beam and the headlite dimmed then slowly came back up to power and it did this everytime I switched back and forth. need some help here, not sure where to look first. Battery is new and seems to stay charged up. I did clean all grounding locations.
    I need to find the problem before I or my wife rides this at nite again.
  • rover
    • Jan 2004
    • 765
    • central WI (715)
    headlight
    You may have a filament (high beam or low beam) burned out. There is a switch (?) that will switch the light to the working beam at reduced brightness. Unplug your headlight and check with an ohm meter for a burned circuit.
    79 F (Blueballs)
    79 SF (Redbutt)
    81 LH (organ donor)
    76 CB 750 (gone to MC heaven)
    rover has spoken
