I have an 80 Special with broken off stripped out valve cover and exhaust bolts/studs in it. I was wondering if I can use a 78 or 79 head on it, or does it have to be an 80 head? Thanks for your time!!!!!
1980 Special Head Issues.
IIRC, you can use early heads (78/79) with late pistons (80/81) but not late heads on early pistons from what I remember. The valves are larger on late heads and I think it will create a collision with early jugs/pistons because the domes are higher. There was a thread where someone did a test to see if the early pistons would collide with late heads and it was close but ended up ok thus disproving the earlier statement. I know there is a bad combination of pistons, heads, and cams that result in valve collision but it's been awhile.
Long story short, keep early cams with early heads and late cams with late heads and you'll be fine either way because late pistons (your 80SG) don't have the higher domes (I think).
Someone will chime in with a correction here in a second.78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
"May my tires not fail me, nor my engine grow cold" -
broken studs
Howdy,..
It seems to me that rather than yanking the head and jumping through those hoops you could locate a GOOD shop to drill,tap or repair those buggered threads, probably cost less than head gaskets and such and less down time as well.....jat78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.Comment
You would still need to take the head off to get those threads repaired...I don't know of any shop that would take a hand drill to an aluminum engine block to drill out heat stressed, broken off steel studs...
Best case he would need to take the head off, jig it up on a drill press, and use some hardened bits. Even then there probably won't be any aluminum left to re-tap once you get the old studs out so you'll need a helicoil or some other sleeve. That wall thickness of the valve cover bolt holes is really thin too so there's not much material that can be relied on later...
Seems like a lot of work to do when you can just bolt on a new (used) head off of ebay for $100 plus the cost of the head gasket if it can't be reused.78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
"May my tires not fail me, nor my engine grow cold"Comment
lucky I guess
I guess I am just lucky,I have a great shop here that has done similar repairs for me including drilling and tapping the bolt holes that hold the cam in....while still in the bike.....old school mechanics..78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.Comment
Before you go and mis-informed a member , maybe you oughta read the RECENT situation that 3Phase went thru just prior to the Colo. rallyIIRC, you can use early heads (78/79) with late pistons (80/81) but not late heads on early pistons from what I remember. The valves are larger on late heads and I think it will create a collision with early jugs/pistons because the domes are higher. There was a thread where someone did a test to see if the early pistons would collide with late heads and it was close but ended up ok thus disproving the earlier statement. I know there is a bad combination of pistons, heads, and cams that result in valve collision but it's been awhile.
. No offense intended, but unless you've BTDT, your chances of mis-information runs high.
Last edited by motoman; 08-04-2014, 12:34 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
You might
want to read this interchange thread put together by CrazySteve.
JimComment
Danger! Will Robinson!
And Steve's got the major technicality covered: "Going the other way will raise compression, but again you need to check piston/valve clearance."want to read this interchange thread put together by CrazySteve.
http://www.xs11.com/forum/showthread.php?t=36652
The minor technicality compared to a possible piston-to-valve collision is the exact year/model the early 2H7 cylinder head came from because the exhaust header collars are different.
The '79SF has the shorter exhaust header collars and studs like all of the '80 and '81 3H5 heads and the XJ's 10M head so a '79SF head will work with a '80SG if the valves will clear the pistons.
A '78E (I believe) or '79F 2H7 head will work with a '80SG if the valves clear the pistons but they will not allow the exhaust system to bolt on without changing the exhaust studs.
.-- Scott
♬Comment
Kind of clearly said that I wasn't 100% sure and that he should wait for a second opinion. Missed the "recent" situation someone went through but I did read a thread about mixing pistons and heads (that ended up with enough clearance in the clay) that I tried to point him to search for....never claimed to be sure of or even confident in my answer.78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
Hey Vanimal
I remembered this thread from earlier this month. It seems that Tcoop has done what you were asking about.
JimComment
To elaborate on his comment, I believe what he is trying to say is if you dont have first hand experience with it or are not 100% confident in your answer (and can list your source) dont make the suggestion. It would be more useful to post a link to the info he seeks or tell him to keep searching.Kind of clearly said that I wasn't 100% sure and that he should wait for a second opinion. Missed the "recent" situation someone went through but I did read a thread about mixing pistons and heads (that ended up with enough clearance in the clay) that I tried to point him to search for....never claimed to be sure of or even confident in my answer.
Providing a reply with a lot of "I think I remember reading" can cause more harm than good. People read it and for some reason it will be the only thing they remember and can cause more damage, or worse it get repeated as fact...Last edited by WMarshy; 08-05-2014, 07:27 AM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Point taken. I'll just refer to a specific thread next time or at minimum provide criteria to use in the search function.To elaborate on his comment, I believe what he is trying to say is if you dont have first hand experience with it or are not 100% confident in your answer (and can list your source) dont make the suggestion. It would be more useful to post a link to the info he seeks or tell him to keep searching.
Providing a reply with a lot of "I think I remember reading" can cause more harm than good. People read it and for some reason it will be the only thing they remember and can cause more damage, or worse it get repeated as fact...78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
I did use a 79F head on my 80LG using the headers from the LG. To make this work I added a lock washer under the exhaust nuts. This may be to redneck for some but I have been running it that way for over a month with no problems. Not sure if over time stress will cause this set up to fail. THIS IS NOT AN ENDORCMENT TO DO IT THIS WAY.
This is how I have it setup.
Replacing the studs is the best solution.Ty
78 XS1100E - Now in Minnesota
80 XS1100LG - The Punisher
82 XJ1100 - Daughter's Bike
72 Yamaha Mini JT2 - Youngest Daughter's bike (She wants a bigger one now)Comment
That looks great, Ty!
The 'wrong' exhaust studs in the head just adds an unexpected stumbling block to putting the bike back together but anyone getting close enough to actually notice and care about washers under the exhaust nuts should change the studs for you or at least offer to buy you dinner or something.
.-- Scott
♬Comment
check your PM's 3Phase
