Self-inflicted Oil Consumption
  • #16
    Originally posted by Murrayf View Post
    why not get one sleeve
    Not a bad idea. One donor sleeve and piston set from a donor engine with good compression and heat block to extract sleeve. No honing or machine shop required.
    John
    '81 XS1100H - "Enterprise"
    • #17
      I've already got several sets of jugs that won't work with standard pistons and rings and any of them can easily be bored out oversize, it's just funds and the odd hexagonal shape of the 'tuits that've come galumphing my way lately that keep that from happening.
      John
      The only heat source I have is the kitchen oven. If I even think about using it to swap sleeves around from different jugs -- ever! there'll suddenly be a lot of donor parts available but they won't be for an XS1100....
      • #18
        The good side...........meanwhile, ya' gots' alot of options to stew over....
        • #19
          I'm almost done with the upstairs bathroom so I'll try to get some work done on the '79F head. I still think that'll be a hoot to run so it'll have to be ready pretty soon because there's a set of pistons, rods, rings and jugs on the way from andreashweiss that'll drop right in.
          I don't necessarily need the rods but this way I'll have something handy to throw at the cats if they sit on the bike and start to ventilate the new B and H Specialties seat cover like they did to the last one.
          • #20
            Kinda figured you were headin' that direction, if nothing more than resolved curiosity.
            The ATV seat cover over it oughta' keep the cats purrin'.
            • #21
              Wow, Scott! I knew that motor was a heavy smoker when you blew past us that time on the ride up to Bishop's Castle 'cause I could not only see some smoke, but I could really smell it.
              But I can't believe those pistons! Oh man! Talk about raising your compression!
              Man, what a drag. Sorry to see this.
              2011 Kaw Concours 14 ABS
              • #22
                Bob, the really, truly bright side out of it all is that I finally found and eliminated that weird intermittent knocking rap that's been in the engine since I bought the bike, even after the rebuild five years ago: piston slap.
                Except for the smoke and oil consumption, with the new(er) pistons and cylinders the engine's never run so quiet since I've owned it. It was just starting to make unhappy noises again when the spark plug went walkabout and I futzed the repair so I put the poor thing on a truck before it really hurt itself.
                • #23
                  well if the piston and jugs were going to go for scrap
                  i will pay to have them shipped here and a nominal amount
                  that way when i have a bit of time i can play around and see
                  how much time it takes to sleeve and finish the 4 holes
                  79 SF
                  • #24
                    Murray,
                    I think I may have misunderstood what you were saying! If you want the XJ11's 10M/3H5 assembly they're yours for shipping or even better I can send the '80G's 2H7/3H5 assembly from Columbo that already had a pretty good case of piston slap going on.
                    Oh, do you want/need the pistons and rings too, just the jugs or do you have something else in mind? If you've got the time and the technology and you're going to re-sleeve anyway you can clean up the pistons to a few hairs undersize, then bore and hone the sleeves to fit the pistons instead of praying the parts will be close enough to spec. that they won't just pretend to be happy while they aimlessly rattle around in their bores and hatching escape plans with their cohorts.
                    • #25
                      i would want the pistons and jugs together
                      then i would bore and sleeve
                      final bore and hone to proper clearance
                      and file fit a set of stnd rings
                      then all would be good
                      i may even knurl the skirts
                      i dont need the rings i will use new
                      79 SF
                      • #26
                        Murray, send me a PM and we'll work out.
                        • #27
                          He's Gone
                          I got a set of decent 2H7 jugs, pistons, rings, rods and bearings from Andreas Weiss. I've started cleaning stuff so I can put the engine back together and I've decided that I am not going to use 3H5 pistons with the 2H7 head. I don't trust the Intake valve-to-piston clearance.
                          When the engine's finished I'll have a 1980 Yamaha XS1100EFGL:
                          '78E jugs and pistons
                          '79F cylinder head
                          '80G engine case and transmission
                          '80LG crankshaft and connecting rods.
                          I'm going to pull the oil pan and rummage around for goodies and treats, then check the rod bearings so the engine may get the 'new' set of matched '78E rods along with the pistons and jugs.
                          This is the #1 3H5 piston. There is seriously thick and heavy carbon built up after less than two-thousand miles.
                          The carbon was sliced with a razor blade, then half of the piston was scraped clean and the depth of the remaining carbon was measured with a digital caliper.
                          The greatest depth of the carbon was in the Intake valve relief cut-out: 0.048 mm (0.019 in)
                          The least depth of the carbon across the piston crown was: 0.029 mm (0.001 in)
                          The rings didn't seat and the engine was slurping two quarts of oil every sixty to one-hundred miles but oddly enough, the gas mileage was excellent and ranged between thirty-five and forty-two miles per gallon.
                          XS11_Piston_Carbon by Scott_Ci, on Flickr
                          After the parts from Canada got here I got another present in the mail so I've taken a short break (a short break!) and I'll be back in a little while: Steal your face right off your head! (~);}
                          Dave's Picks, Volume 11
                          I don't think we're in Kansas any more!
                          The Grateful Dead recorded live at the Century II Convention Hall in Wichita, Kansas on November 17, 1972.
                          DP_V11 by Scott_Ci, on Flickr
                          • #28
                            '79F cylinder head
                            Now, that beats workin' on imported mechanical aluminum parts anyday!.
                            • #29
                              You betcha!
                              Since the 'new' 2H7 jugs and rings are already broken in to each other I could put the 2H7 rings on the 3H5 pistons but that's a little too hokey and I see another teardown in the not-too-distant future if I try to get away with something like that.
                              Oh, well, it would have been fun.
                              • #30
                                You betcha!
                                Besides.......you got a 79 that I'm still lookin' forward to seeing finished......white, black soft cases, smoke shield........now THAT just LOOKS like it's about takin' care of business.......with the right hand.
