Oil coming out of airbox.
  • BobBaldy
    • Apr 2012
    • 43
    • Evansville IN
    The sightglass is black. The confederate is missing because the p.o. took it off to put Jardine spaghetti headers on and then lost it.
    For pics click the link in my signature. Too bad I didn't keep up with that blog. I'll catch it up someday.
    80 G, Spaghetti pipes, K&N in stock airbox, Galfer S/S lines.
    It has been my experience that folks who have no vices have very few virtues. -Abraham Lincoln
    http://80xselevenrebuild.blogspot.com/
    • BobBaldy
      • Apr 2012
      • 43
      • Evansville IN
      Centerstand not confederate damn autocorrect.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        Only way to clean the sight glass is take the clutch cover off and fish a pipe'et cleaner behind it. Little shot of ether on it will break it up and dry without residue. Try leaning the bike against the wall upright to check the oil if you don't have the center stand.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
          • 3954
          Even the slightest grade difference from having it on anything but a flat surface will throw the oil line off in the sightglass. Don't go by that glass if you're sure you put the required amount of oil in. Or, find a surface that makes your required fill a true statement.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            line level
            Even on what looks like a level surface I use a maple wedge under one of the legs of the centerstand and a line level on the valve cover to make sure. Without the centerstand I think you would need to use a bike jack/lift and then level that until your line level shows level. Trying to level it with just the side stand it's likely to tip over
            76 XS650 C ROADSTER
            80 XS650 G Special II
            https://ibb.co/album/icbGgF
            80 XS 1100 SG
            81 XS 1100LH/SH DARKHORSE
            https://tinyurl.com/k6nzvtw
            AKA; Don'e, UD, Unca Don'e
              Originally posted by cajun31
              is that you have too much oil in the bike. You stated that you put 5 quarts in... the specs from the manual with oil and filter change is 3.7 U.S Quarts. If you don't change the filter then it is only 3.2 quarts. You need go ahead and drain all the oil out and replace the filter and oil and follow these specs. I would think your compression is fine but it wouldn't hurt to know for sure.
              Again wrong, 4.2qts with filter change as per the original owners manual.
              Basicly, if no centerstand and not tottally sure of holding perfectly level when changing oil AND filter............4quarts.......cap it and go ride.
                BTW, if one has the Standard 81H model(Venturer), its initial capacity is 4.4quarts due to the optional factory oil cooler. Filled correctly, oil level COVERS the window fully.
                  Yep...........
                  • Prisoner6
                    • Aug 2013
                    • 1184
                    • Phoenix, AZ
                    ... you have too much oil in the bike. You stated that you put 5 quarts in... the specs from the manual with oil and filter change is 3.7 U.S Quarts. If you don't change the filter then it is only 3.2 quarts. You need go ahead and drain all the oil out and replace the filter and oil and follow these specs.
                    Brant,
                    I believe cajun31 is correct. On page 38 of my original owner's manual, it says this:
                    Periodic oil change:
                    3.0 lit (3.20 US qt)
                    With oil filter replacement:
                    3.5 lit (3.70 US qt)
                    When changing oil and filter on my SF (using centerstand on level ground), I refill with oil until it reaches the top line of the sight glass,
                    and I have never had to use a full 4 quarts. Bob's bike is a G with no apparent oil cooler, so it should be the same amount.
                    Marco
                    1979 Honda CBX
                    2002 Kawasaki ZRX1200R
                    WE MISS YOU, DON
                      Originally posted by Prisoner6
                      Brant,
                      Better have another look at that...........page 90, original yellow owners manual(4RO-28199-10). Not sure what your lookin' at, but this IS out of the original owners manual that came with my bike when I bought it new. BTW, 3.2qt. without filter change IS correct.
                      • Prisoner6
                        • Aug 2013
                        • 1184
                        • Phoenix, AZ
                        Hi, Brant -
                        I'm looking at my original yellow-with-black-lettering SF owner's manual, part #3H3-28199-10 ...
                        And since Bob's bike is an '80G with no oil cooler, not an '81H with oil cooler, his oil capacity should be the same as mine, yes?
                        Marco
                        1979 Honda CBX
                        WE MISS YOU, DON
                          It's 3.7 with a filter change.......the end. GEEZE!
                            +1!..........Oli/ filter change, put 4quarts in the damn thing, cap it and go ride!.
                            • Prisoner6
                              • Aug 2013
                              • 1184
                              • Phoenix, AZ
                              Hi, guys -
                              3.7 quarts with filter change ... isn't that what cajun31 originally posted?
                              Seriously, though, I just wanted to make sure Bob had the most accurate information for his bike, because I know how much we all strive for accuracy.
                              No offense intended to anyone ...
                              Marco
                              1979 Honda CBX
                              WE MISS YOU, DON
                                Hi, guys -
                                Thick skinned......no offense taken. All the XS11 series the same oil capacity, cept for the Venturer and its factory added oil cooler. No biggie, have just put 4qts. in with oil/filter change for DECADES with no issues.
                                If new to the bike......and bike new to you, may wanna watch for internal leaking of petcocks and float needles that WILL fill the crankcase with fuel if left on centerstand, along with leaking fuel out airbox. Not noticed and ridden WILL ruin your XS11 experiece.
