Large round vs small round mains
  • Clyde K.
    • Sep 2010
    • 83
    • Grand Junction, CO
    I just put an after market 4 into 2 exhaust system on my 11E and research says I need to increase my mains to 140s. Seems I just read I need Large Round mains. What is the diff?
    Gunnery Sergeant, USMC (Retired), (A gung ho, lifer, Devil Dog) Semper Fidelis
    XS1100E, 11.5" XV1100 shocks, "no name" 4 into 2 headers and turn out mufflers, stock air box, 140 mains, spade type fuse block, volt meter, LED conversion on running/turn/brake/tail lights, aux front driving and running light bar, 850 FD swap, Chrysler electronic VR. Ugly as a monkey's butt - runs like a scalded ape (WHEN IT RUNS)
    • 4015
    The diameter of the head/screw pitch, and the orifice of the jet.
      Only difference between large round and the small round main jets is the size of the head on the jet. For our stock carbs the main jets are of the large round type.
      The threads and the jet orifice are the same for the same numbered jet.
        Hey Clyde,
        The jetting guide is just that, a guide, not written in stone. The earlier bikes were jetted a bit richer, and got leaner in the later years with the EPA standards. SO....stock your mains are 137.5. Before you go changing jets, put in some new plugs, and ride the bike for a while, see how it behaves in the TOP END rpm range, and then do a throttle chop technique to see what your plugs show. If you have a little color/light tan or such, and no sensation of running out of power in the top end, then you may not really need to rejet at all.
        • James England
          • 3039
          • North of England
          I've fitted several 4 into 1's and two 4 into 2's. In all cases, I never felt the need to re-jet. It's only advice and probably more of a disclaimer just in case there's a faint possibility of it affecting carburetion. Personally, I'd fit the system, ride the bike and see how it feels. If there is no noticeable deterioration in performance, I'd just run it! Maybe do the throttle chop and check the plugs but I wouldn't be unduly concerned re jetting if there is obviously nothing amiss.....IMO....
            Leave jetting as is for a baseline for plug readings BEFORE any re-jetting Clyde.
