Okay. Still working on the 82'XJ1100J. I thought I was dealing with carburetor problems, and I was, but I have run out of things to check and fix. Done all the cleaning, replaced throttle shaft seals, worked out any possible vacuum leaks, triple checked the float levels, adjusted the valves. Synched carbs. I finally have an idle that is smooth, balanced and stays were you put it. It's to the point where I can ride it enough to check on my tranny repair. Tranny shifts good and doesn't come out of gear. Hurray and thanks for the tech tips.
So, now the bad. It is still very undriveable. Bogs bad when you open the throttle off idle. If you can get the RPM over 3-4 grand it will run like a raped ape, pulling hard right up past 7000. But let it drop to 2000rpm, open the throttle again, and you have to pull in the clutch to keep it running. My thought was that it's not getting enough gas in the transition above idle, going lean, so I checked the float levels again, but they are all right at the 3mm spec.
Reading on XJ4ever site last night, a guy brought up power loss due to corrosion in the wiring.
Could I have a electrical power problem causing this? The coils are new and check good. When I check voltage at the ignition module orange and red wires with the key on I get 10.8 volts, which is about 1.4 volts under under battery voltage. Seems wrong to me. I get battery voltage at the back of the key switch until I turn it on, then it drops 1.2 volts. Huh?
To many things to chase around here. It's making me age very fast. I'd like to ride this bike more than I wrench on it.
Any help is appreciated.
DW
DW
