Fuel
  • mack
    • 2411
    • Ontario, Canada
    Fuel
    Anyone know what the octane comparison was from 78 to now for regular gas. I suspect it was the same but it was pure gas back then with a bit of lead in it. But now we have corn etc added to make up the volumn. I read recently that todays gas burns cleaner, but does it compress and combust as well as the gas did back in 78/79?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    On this side of the border, we've been using the same rating system, (R+M)/2, since before these bikes were born. Lead was being phased out by then as well. I remember mixing my fuel at the pump if I could. I'd get half full with leaded and top up with no lead. 89 leaded was as high as I could find as I recall. Unleaded used to be 91 where I shopped. Seat of the pants, I don't think there's really much difference. My bike runs fine on corn gas even though I do my very best to avoid it.
    • rdmcguy
      • Jul 2013
      • 515
      • Denver, Colo.
      Gas
      I don't know the chemical makeup of old school gas versus modern but in the early 70's but Sunoco 240 versus the lower grades would give you enough of an edge to beat a similar machine..in my case rd 350's ...also you could wheelie one gear lower with the better gas/higher octane...
      I think modern era gas is trash...but what are the options?
        • 3372
        Just got back from Kansas, looking forward to the Colorado '14 Rally starting tomorrow!
        I don't know two strokes all that well but the same principles should apply as a 4 stroke... If the comp ratio warrants higher octane, then it will produce better power because the fuel burns optimally/at the correct rate for the engine design. Thus your better performance, in all likelihood, rdmcguy.
        The XS produces best power on lower/standard grade. Because higher octane burns fractionally slower, it finishes burning going out the exhaust, thus not giving all it can to push the piston, and has been proven to carbon up exhaust valves as a result.
        If an RD had a high enough CR for a two stroke that more octane was actually needed than low test could provide, it would make more power all else equal, IMO.
        For example, my ZRX1200 is a relatively mild 10:1 CR for a modern 4 valve engine and I run low octane with no issues, even with a +4 degree timing advance rotor.
        The ZZR1200, which was/is probably the fastest carbureted bike in the world to this day is the exact same engine as the ZRX other than .5 CR higher pistons and larger downdraft carbs. It has a 10.5:1 CR but calls for high test due to the ram air system it uses, thus effectively boosting the CR by force feeding the equivalent of a couple psi like a turbo at higher speeds, and thus the higher octane is called for, at least that's my take on it.
        Normally boosting a CR by .5 on an engine that was not already on the edge will not need much, if any change in fuel.
        I have ZZR 1200 pistons ready to go in the ZRX and everyone that has done that says it does not change the octane needs.
        Guys that "treat" their engine to higher octane if the engine does not need it are absolutely doing their bike NO favor and could lead to carbon'd exhaust valves and will have lower power output vs a lower octane.
        For Colorado riding, lower octane is even more agreeable to engines because less dense air (lower oxygen to burn the fuel being drawn in as well) takes up less space in the combustion chamber in a naturally aspirated engine, and CR is effectively reduced because there is less air being compressed and no way to pack more in and make up for it since it is being drawn in and not forced in.
        Dragsters at Bandimere speedway run higher boost compared to lower elevation, as another example, because they need to re-gain the packing of the combustion chamber to offset the less dense air to get back to the effective crazy high CR they run at lower elevation.
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • Rich*11sg
          • Jun 2014
          • 9
          • Inverness, FLA.
          I run 93 in my bike as it has over 64k miles on it and the carbon build up on the pistons raised the CR high enough to need it. although i probably should just fix that, but you know, i'm lazy.
          1980 xs1100sg "some kind of cafe/tracker hybrid thingamajig" wip.
            If you pour some B12 Chemtool or SeaFoam into the carbs when the engine is running AND warmed up, let it die from the mix, and then start again after about 20 minutes it should take off a LOT of the carbon. An easy way to do this is put four tubes on the carb boots, and put them into a can with the seafoam. It should be sucked into the system that way.
            • Rich*11sg
              • Jun 2014
              • 9
              • Inverness, FLA.
              I'm not too lazy to seafoam the motor, just too lazy to resync the carbs afterwards.
              Although I have to after the valve adjustment, i'll just do it all at the same time.
              • mack
                • 2411
                • Ontario, Canada
                update
                So I’ve done some more research on ethanol. Apparently it is powerful solvent that will break down any crud in your tank or filters and allow it to pass into your carbs. It also attracts moisture from the atmosphere but will only hold it in suspension up to a very low percentage then everything breaks down rather quickly and you lose it’s already low octane value and combustibility. Considering how our carbs are vented, this is not a good thing. In general, ethanol fuels burn with lower energy than the traditional fuels did, and will leave behind excessive residue, foul your plugs and valves over time. Despite government claims, this fuel is junk. It doesn’t help the environment because it decreases fuel economy by not completely burning everything in the cylinder and pushing it past the valves into the atmosphere. What a sham. Unfortunately up here the price of gas is already too high and using high test is not really an option. Our only alternative is to frequently use fuel additives like sea foam or star tron to limit the damage being caused by this junk.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                  • 6765
                  I am fortunate to live in a state that has independent retailers that sell Non-ethanol gas...in fact theres a station right in my town...about 5 miles from me.
                  Its simple...ethanol is crap...engines are less powerful...run less efficiently...and get poorer gas mileage... Some people claim they notice no difference in performance but I sure do...when I am travelling away from home I carry a list of Pure-Gas stations where I am heading...
                  Pure-gas.org is the definitive web site listing stations that sell pure gasoline in the U.S. and Canada.
                  2005 Honda SilverWing 600
                  2018 Honda PC-Xpress 150
                    http://www.pure-gas.org/
                    I have the Pure Gas app on my smart phone. I use ethanol free whenever it's possible, but I can't tell any difference in how it runs or in economy. It makes a bigger difference in my wife's Ford Focus.
                      Good option............if you don't LD ride much.
                        I know
                        for sure that the ethanol is crap and does not burn as hot nor do you even approach the mpg that traditional gives you. Used to drive long distances for work in a flex fuel vehicle. One day we decided to fill up with ethanol based fuel versus non ethanol and we noticed that after a 300 mile trip that we were not averaging the same mpg. It turned out that we lost 60 miles on that tank. We quit using the ethanol. Of course now most of us have no alternative because it is the only thing available. Back then we had a choice. I am with Mack on this it is crap... does nothing for the environment and if you give it serious thought it is driving up the cost of everything else around us. You noticed meat prices lately.... that is for those of us that are meat eaters. Big government ploy is all it amounts to. That is why I throw in Marvel Mystery oil to supplement the gas. I do notice a difference in the valve noise when I use it versus not using it and hopefully it is helping alleviate carbon buildup and damage the ethanol is doing.
                        • MPittma100
                          • Aug 2011
                          • 2359
                          E0
                          When I run E0, I get better fuel mileage/performance on both a 1979SF and a 1981H - more noticeable on the Venturer. Mileage goes up to 42 from 36-38 and seat of the pants better feel on engine response. Special gets 35 mpg with E0 and a couple less with E10. Best result is from leaving E0 in the tank if bikes sit for extended period. No carb issues as a result. Both bikes mentioned have stock jets, stock exhaust, K&N air filters. Special has Dyna coils.
                          I have been told by 3 service managers at 3 different motorcycle/watersport/4 wheeler dealerships that 95% of fuel related problems that they repair are caused by Ethanol. I have no reason to doubt them.
                          I keep E0 around for all carbureted engines - chain saws, weed eaters, lawn mowers, bikes, 4 wheelers, generators, etc. I have access to E0 within 5 miles of my shop. Have only been using E0 for a little over a year now. It has proven itself in less fuel system maintenance/costs and better driveability.
                          E0 works for me.
                          Mike
                          1981 XS1100H Venturer
                          K&N Air Filter
                          ACCT
                          Custom Paint by Deitz
                          Geezer Rectifier/Regulator
                          Stebel Nautilus Horn
                          EBC Front Rotors
                          Limie Accent Moves On In 2015
                          Mike
                            ditto
                            on the E0. I drive 10 miles to get that for all my lawn equipment. I don't use any ethanol based fuels in that equipment. Carbs are too small and I am not risking damage. I was warned by the folks I bought my 4 stroke weed eater from about what ethanol based fuels would do to them and heeded that warning. I also use some stuff called mechanic in a bottle available from home depot that I add to a small 1 gallon fuel can that I then use at the beginning of each season. I remove all old fuel... put this mix in and start the engines long enough to cycle this through a bit.... I then let them sit for a couple of days as recommended on the label to break down deposits and everything runs great after that. I have actually resurrected some severely abused small engines this way. Damn ethanol.
                            • mack
                              • 2411
                              • Ontario, Canada
                              percentage
                              I think they actually raised the percentage of this crap in Canada. I'm really pissed at this.
                              mack
                              HERMES
                              original owner
                              81 XS 1100 LH MNS
                              SPICA
                              78 XS 11E
                              IOTA
                              613-398-6186
