Coil problem XJ1100J Maxim
  • evanste
    • 1
    Have tried the solution suggested on tips page and had no luck any further help appreciated
    Cylinder 1 and 4 not fireing checked coil primary and secondary resistence which check out ok. the pickup coils resistence is 110ohms the book states that they should be 600 ohms another bike witch we can test has pickup coil resistence of 110 ohms again. problem is if the book is correct two bikes have very low resistences. if the book is wrong are these the correct resistences (the make of the manual is Climer).
    Thanks in advance.
