Advice needed - Need Solenoid for XS 1100
  • Advice needed - Need Solenoid for XS 1100
    Hi there,
    Need some advice on which type of solenoid i will need. Any recommendations on one over another?
    Basically, my bike won't turn over unless i tap the solenoid to the frame of the bike. I've tested the ground, starter button, etc...and all is working.
    I have a 1981 Yamaha XS1100 Special.
    Any advice or info is much appreciated.
    Thanks!
    81 SH
    Slick,
    If tapping the solenoid against the frame makes it work there might be a broken coil wire or solder connection right at the cover of the start solenoid or it's just partially rusted in place. It's not too difficult to clean and fix the solenoid, I had to repair the one on my '80G and it should be the same as the one on your '81SH.
    See the second and third pictures in the thread:-
    Solved: Why the ignition died and the starter would not work
      Scott,
      I don't think the type of solenoid I have can be taken apart...I'll try. It's a different style then the one you have in the picture.
      I'll let you know how it goes. thanks!!
      81 SH
        Solenoid?
        Originally posted by slickatwork View Post
        Hi there,
        Thanks!
        Is it the starter solenoid you are looking for? Try this link:
        http://www.ebay.com/sch/i.html?_odkw...enoid&_sacat=0
        Mike
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          Mike,
          That's what I need. Thanks!!
          81 SH
